Author Topic: wiper motor installation and rubber boot brake pedal  (Read 3126 times)
rjgricius1
  • USA, MI, Mount Clemens
« on: October 30, 2011, 23:36:01 »
is the rubber boot that sits on the brake light switch mounted on the brake pedal available?
Also, are therer any instructions on installing the wiper motor. I sent mine out to be rebuilt
and wonder if there is a trick to realinging it under dash.
230 sl 1967 automatic
wht/blue  in the middle of comple restoration
Re: wiper motor installation and rubber boot brake pedal
« Reply #1 on: October 31, 2011, 14:02:03 »
On the latter question, IIRC, the bolt holes and the bolt pattern only fit one way
I installed a recon unit in mine and had no instructions whatsoever and yet managed it. Which suggests that it's a pretty idiot-proof process. There'll be a thread on here somewhere if you run a search
rjgricius1
« Reply #2 on: October 31, 2011, 16:52:50 »
Thanks Tosh,
I have reinstalled the motor and all mech. under dash, but need to know how the wiper motor arm is attached to the long arm underdash that pivots.
