On the first test drive after some work on the engine, I noticed some hesitation almost bordering on missing when I am entering the ramp onto the freeway (2000-3000 RPM @ 50-60MPH). It runs great at lower speeds, good at idle but stumbles a bit on the highway during acceleration. Starting is also a bit longer.
I replaced the timing chain because I did not know its age and was doing a lot of work on the front of the engine anyway. During the replacement, I am pretty sure the distributor/IP drive gear slipped one tooth on the chain. Because I had the distributor housing off, I could see the gear and was able to correct the mistake (so I thought). After the chain replacement, I matched up the cam and crankshaft marks and reinstalled the distributor EXACTLY the way I took it out. Something didn't look right because the mark on the distributor body did not line up with #1. I went ahead and checked the ignition timing anyway and it was 40-60 ATDC or very late! The engine wouldn't start of course until I moved the distributor drive gear one tooth and adjusted the body clamp. Now it is 30 BTDC @ 3000 RPM. Because I had to move the distributor drive gear one tooth for it to be correct, I am thinking the IP pump timing is off.
If the timing is indeed off (late) by a tooth or two on the drive gear, would that cause the symptoms I have descibed above? The spark plug color looks ok and the ignition timing is right on. I also did time the valves with a dial indicator and they are only off by two degrees. BTW, I have a 123 distributor that was working well before the work. I also had the injection pump off a few years ago, so I know it was in time before the work began. The fuel mixtures seem to be OK when I split the linkage at idle, 2000 and 3000 RPM.
Before I go to the trouble of removing the pump to check the timing, I wanted to get some expert advice and see if the timing could cause the symptoms. Seems like if the pump timing is late, the engine would run lean and therefore the hesitation. How far off can the timing be before you start noticing problems?
Thanks for the help!!!
