Author Topic: How difficult to remove fuel tank?  (Read 3002 times)
Dave
« on: October 31, 2011, 20:52:19 »
Just wondering.  It's still putting out rust and dirt.  What's next steps, coating inside with por-15?
Jordan
  • Canada, ON, Jordan
Re: How difficult to remove fuel tank?
« Reply #1 on: October 31, 2011, 22:39:48 »
Dave, I would recommend you bite the bullet and put in a new tank.  There are plenty of threads you can search as this has been discussed at length many times.  You won't have to worry about the rust issue again.  I replaced my tank myself (230SL).  It was relatively simple.  Just remember to take all necessary precautions when dealing with gas and fumes.  Drain all fuel from the tank, disconnect and remove fuel sender, disconnect fuel lines, disconnect the breather tubes (you can access these by removing the round cover at the front of the trunk to the right), remove gas cap and rubber surround, and unscrew the 4 screws holding the tank in place.  I don't think I forgot anything.  You might have to work it a bit to get it out.  You should not have to remove the muffler, although you may have to loosen the screws holding it up so you can move it a bit if it is very close to the tank.  I'm not especially mechanically inclined so I am amazed I actually did it myself.
Good luck.
Marcus
66 230SL  Euro 4 speed
GGR
  • USA, DC, Washington
« Reply #2 on: November 01, 2011, 00:35:26 »
I don't know how much is a new tank but I had excellent results in having a tank dipped into an acid bath and then using the POR tank treatment kit.
Ulf
« Reply #3 on: November 01, 2011, 11:45:49 »
Not that expensive, here is a link: http://www.sls-hh-shop.de/index.php/cat/c3_Mercedes-Benz-230SL-250SL-280SL-Pagoda--R113-W113-.html#cat_76_position_2_prod_0
Please note that this is for a 250 or 280, not the 65 liter for the 230
Ulf
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
