Author Topic: dipstick pipe A127 010 08 66  (Read 3144 times)
« on: November 04, 2011, 18:39:14 »
Does anybody of you know how to pull off the engine's dipstick pipe from the (large) oil pan?
Mine is rusty and I would like to have it zink-plated.
It appears to me that it is only stuck in but not screwed in or so. It's tight, could it be that it is glued? :o
Or is it possible to just pull it out?
Many thanks in advance,
Re: dipstick pipe A127 010 08 66
« Reply #1 on: November 05, 2011, 00:28:19 »
Hello Achim,
They are a tight fit, but are just forced into place. Most likely the factory used a little sealer around them. I always use heat on the aluminum around the pipe. Then twist back and forth while pulling upward.  It seems to help a lot.
Tough ones may require a slide hammer to remove. Fit a collar around it and hook the slide hammer to the collar and pop it out.
« Reply #2 on: November 07, 2011, 20:40:20 »
Dear Joe,
Thanks a lot for your advice.
I will give it a try.
