Author Topic: Power Steering Return Hoses  (Read 3505 times)
dirtrack49
« on: November 11, 2011, 18:55:01 »
I found my power steering return hose from the reservoir to the box leaking on my 1966 230SL. I mearsured the pipe from the box at around 12mm and ordered some bulk hose. However, after getting the hose off, I found that the pipes flare into a larger size.
I am quessing that the size needed for the return hose to be around 15.5mm. Not sure what was used since the line I removed measured out at approximately 5/8 inch or less. I can't seem to find any vendors that say what size the hose actually is.
Anyone know what the bulk hose size requirement is for the return hoses?
Since I would need to mail order sizes in millimeters, would a 5/8 inch hydraulic hose from the local Napa store do the trick?
Tom L
66 230SL
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: Power Steering Return Hoses
« Reply #1 on: November 12, 2011, 00:20:14 »
Call the classic center.  They will sell the correct size.  The price is reasonable too.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
dirtrack49
« Reply #2 on: November 12, 2011, 01:47:48 »
Hi Brad,
I found the proper size was 15mm.
I need to get some kind of parts listing for these vehicles before I end up having a parts store of my own.
Every time I start up on a new found vehicle, I always end up ordering all kinds of parts I don't really need. The 230SL is no different.
I tell myself that I will put the extra parts in a bin, just in case I might need them someday. The bin after some 40 years,  is getting really big and there is no inventory system.
Before I go overboard on this project, can someone direct me to where I can find a parts catalog with the proper part numbers?
Thanks again,
Tom L.
« Reply #3 on: November 12, 2011, 04:51:27 »
Hello Tom,
take a look here first:
http://www.sl113.org/wiki/Documents/SparePartsList
and then search on eBay for this parts list (p/n 10126) but make sure that you do not buy the "parts catalog" that came with every car since it does NOT contain part numbers.
The p/n for those catalogs all start with 12xxx, see: http://www.sl113.org/wiki/Documents/PartsCatalog
However, be also aware that the part numbers in the list are the original ones and many were replaced over the years but at least it gives you a start especially when you input the number into the electronic parts catalog (EPC): http://epc.startekinfo.com/epc/
dirtrack49
« Reply #4 on: November 16, 2011, 01:33:19 »
Hello Alfred,
Thank you for the good info.
It will certainly make things a lot more easy when it comes to ordering parts.
Tom L.
66 230SL
