Author Topic: fuel injection pump oil change  (Read 10482 times)
gnj588d
« on: November 17, 2011, 15:35:34 »
Going to do an oil and filter change next week,its done 700mls since the last change 12 months ago,I feel it should be done or am I wasting my money.while I am  at it I am looking at the fuel injection pump(its the early one with a dipstick) how often should the oil be changed and is there a drain plug to remove it,I cant see one.if not how do you remove the oil. ??? Many thanks. Mike.
knockmacool
Re: fuel injection pump oil change
« Reply #1 on: November 17, 2011, 17:29:10 »
Use the squirt pump off your hand cream bottle. 700 miles- that's more than me!
Larry & Norma
« Reply #2 on: November 17, 2011, 17:34:27 »
I did 6000 miles between oil changes last year, oil still looked pretty good!
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
« Reply #3 on: November 17, 2011, 22:46:38 »
The oil in the pump doesn't need to be changed very often. I'd be more concerned if the oil level increases above the full mark as it would indicate that fuel is leaking into the pump. The oil will become diluted with fuel which provides for very little lubrication of the fine moving parts inside of the IP.
scoot
  • USA, CA, Altadena
« Reply #4 on: November 18, 2011, 04:34:33 »
Yes, I had that problem and changed the oil in the IP.  Then the car got taken apart for painting...  2 years later it's driving again.  I guess it's time to get the big syringe and a plastic tube and suck the oil (or oil / gas) out of the pump and fill it again....   Hoping for more oil, less gas.
By the way, I got a syringe that is about 1" diameter and 5 inches long that a tube can be put over.  I'm hoping that saves me a lot of time getting the oil out of the pump...
Scott Allen
'67 250 SL (early)
Altadena, California
scoot
  • USA, CA, Altadena
« Reply #5 on: November 18, 2011, 04:35:24 »
what is the correct oil to put in the injection pump?  Isn't it just 30 weight or something like that....?
Scott Allen
'67 250 SL (early)
jacovdw
« Reply #6 on: November 18, 2011, 08:33:45 »
Generally speaking, you use the same oil in the injection pump as you would use in your engine.
Quantity is about 250 mls.
gnj588d
« Reply #7 on: November 19, 2011, 10:38:52 »
Thanks everyone for your help there was 230mil in the I.P.have replaced it with 250 mil. doing engine oil and filter change today.Thanks again.Mike.
« Reply #8 on: November 27, 2011, 00:46:09 »
I change the inj pump oil every 12 monhs and the engine oil and filter every 6 months.
Also I lube (1-2 drops of oil) the felt wick in the top of the distributor shaft every 6 months
« Reply #9 on: November 28, 2011, 21:03:06 »
Be sure to check for the internal upper rubber filter seal when changing that oil filter or you are slowly wasting your engine. This rubber seal does not come included in  your oil filter kit.  I just serviced another  W113 which had this seal missing for years. The unfiltered oil was extremely dirty and black as ink.
