Author Topic: B.Booster & M.Cylinder  (Read 3000 times)
SilverSpear
  • Abu Dhabi, UAE
« on: November 18, 2011, 05:54:46 »
Hello all,
I am done with stripping down and parts labeling on my 67' 250SL just yesterday.
I have a question related to the brake booster and master cylinders on it. I am pretty sure they are replaced with the wrong numbers, since my car has one brake line going to the back and two in the front, whereas the master cylinder has 4 lines of which one was deleted.
Can somebody please help me out with the right numbers for my car for both units? My engine number is 12993212001330. my Vin number is 11304312002721
Thank you guys.
Dan
Euro 2013 Mercedes 350SL
jacovdw
Re: B.Booster & M.Cylinder
« Reply #1 on: November 18, 2011, 08:52:49 »
Since your car is an early 250SL, you should have a version 3 master cylinder.
However, this has been superseded by version 4 which is what is currently available from MB (part number A002 430 28 01).
The actual change to version 4 was introduced in September 1967 (chassis number 043 xx 002980 onwards).
The master cylinder should have only 3 ports, the rearmost one for the single line to the rear brakes and 2 ports for the front brake circuit.
On earlier cars, the bottom port (front brake circuit) is blocked off with a bolt and a copper crush washer as these cars have a brass T-junction mounted on the fender that splits the lines to the respective front brakes.
As for the booster, the MB part number is A000 430 55 30. Made by ATE and also known as a T51/200 unit.
SilverSpear
  • Abu Dhabi, UAE
« Reply #2 on: November 18, 2011, 19:53:48 »
Thank you Jacov, so having a master cylinder with 4 lines of which one is deleted is perfectly normal...
