Author Topic: Really need a center cluster glass .  (Read 2678 times)
erickmarciano
  • Canada, Quebec, montreal
« on: May 29, 2004, 19:37:13 »
Really need a center cluster glass anyone got one for sale?
thanks
Erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: Really need a center cluster glass .
« Reply #1 on: May 29, 2004, 20:31:14 »
A good household glass or mirror shop should be able to make one easily and fairly inexpensively. An artglass workshop will also be able to do it. I made one myself once. It took about three tries, a diamond drill bit will bore the hole for the light dimmer shaft. A special grinding wheel is needed to finish the edges after cutting the glass.
Some of the instrument rebuilders should be able to get a replacement glass for you also.
Bill Rader
« Reply #2 on: May 30, 2004, 17:16:24 »
Hi Eric,
Try looking on on E-Bay.
I broke mine cleaning it and made one out of plexi-glass.It is just a temporary fix though.Eventually it will scratch up from cleaning but you can't tell it from the original right now.
Bill Rader
'68 250SL
