Author Topic: 1964 230SL Radiator...  (Read 4991 times)
Wolfmann
« on: November 27, 2011, 11:02:00 »
Hi all,
My main radiator has a flat top and is not the same as others I have seen albeit mostly on 250's and 280's. It is clearly not a very modern replacement and looked in the same condition as the rest of the engine bay before restoration and rebuild by a radiator specialist.
Have I got the wrong one ? (it fits fine).
Steven
« Last Edit: November 27, 2011, 11:06:03 by Wolfmann »
IXLR8
Re: 1964 230SL Radiator...
« Reply #1 on: November 27, 2011, 20:41:51 »
Hi--
Can't answer your radiator question, but I like what you've done with your oil filler cap.
the other Joe
Wolfmann
« Reply #2 on: November 27, 2011, 20:52:03 »
Thanks Joe, It is a hood badge from another model (don't know which, got it at an autojumble) and it just happened to fit exactly on the flattened part of the oil cap.
Steve.
DaveB
« Reply #3 on: November 27, 2011, 23:12:18 »
Not original but if it fits and works...
Here's an original 1965 radiator, part number 113 500 04 03.
DaveB
'65 US 230sl 4-speed, DB190
Wolfmann
« Reply #4 on: November 27, 2011, 23:14:39 »
It sure fits but I wonder about whether or not it will deliver the same cooling amount, I guess I will have to watch the temp when we finally fire her up !
Where should they run on the temp gauge ?
Steven.
rocketman1
« Reply #5 on: November 28, 2011, 01:37:22 »
Steven, Boy your engine compartment looks fantastic!!
Que. how did you get the parts(ie:radiator resv. fuel lines,etc.) to have that brass or gold color?
rocketman1
1964 230 SL ZFS 5-20
  • USA, WI, Mequon
« Reply #6 on: November 28, 2011, 02:10:04 »
How's the 123?
Wolfmann
« Reply #7 on: November 28, 2011, 15:06:09 »
Hi Rocket, it is just passivate or cadmium plate (don't know which) but is very cheap if you prepare the parts yourself by media blasting. The flat round coolant expansion tanks are brass so I just sand blasted it and then spent a day or so with a drill mounted polishing kit - I wouldn't want to do it again and learned what a skilled and dirty job metal polishing is ! I think you could strip the tank yourself and have it polished professionally for very little cash. It probably offends the purists but I like the fact it is brass and you do not see brass on euroboxes nowadays !!
Hi Thelews _ Haven't had the car running yet so I can't venture an opinion although I have heard good things about the system from other users.
S.
« Last Edit: November 28, 2011, 16:19:32 by Wolfmann »
