Author Topic: Data Plate  (Read 3903 times)
tel76
Data Plate
« on: December 12, 2011, 08:39:33 »
I have come across a data plate (the one adlacent to the brake booster) that on the third line has the following -
             113 043  10    0
What does the "0" on the right signify?
In the tech: manual 0  and 9  are not used as a market/distributor location.
Eric
Re: Data Plate
« Reply #1 on: December 12, 2011, 22:56:23 »
Interesting, 9 is listed as Australia in the sheet on distributions.
Could this have been  replacement plate??
tel76
Re: Data Plate
« Reply #2 on: December 13, 2011, 08:43:59 »
The condition of the plate and the origional paint around it (it has not been repainted) suggests it came out of the factory with this plate.
Where did you see the # 9  Australian info: ?
Eric
Re: Data Plate
« Reply #3 on: December 13, 2011, 18:26:46 »
It is in the technical manual
http://www.sl113.org/wiki/DataCard/DealerandCountryCodes
In case the link does not work - go to the Technical Manual tab, then scroll down to contents. Click on the "Data Cards and Codes" link. Scroll down on the page to "Dealer and Country Codes"
« Last Edit: December 13, 2011, 18:31:41 by Jonny B »
tel76
Re: Data Plate
« Reply #4 on: December 14, 2011, 08:44:13 »
Thank you i should have seen that.
There is no mention of a "0"  I thought Achim would have responded with the answer.
Eric
Re: Data Plate
« Reply #5 on: December 19, 2011, 16:01:19 »
Quote
Achim ...??? ??? ???
Why Achim, is that guy a library?
Well, I have seen the "0" on the data plates for 2 times so far but right now I don't remember exactly the meaning of it was.
Also for "Diplomats" or that kind of people, or stayed (for a limited time) with MB (car for factory purposes) or something like that.
Let me check again what I have ....
Sorry,
