Author Topic: Compression test  (Read 4576 times)
Compression test
« on: December 22, 2011, 20:43:44 »
A compression test was done on a car that I was interested in and the figures are as follows.
Dry Compression test
1:125psi
2:130psi
3:130psi
4:140psi
5:140psi
6:145psi
A wet test gave similar results.
To me these are not very good.  Any comment?
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Re: Compression test
« Reply #1 on: December 22, 2011, 21:01:17 »
#1 looks bad and #2 and #3 aren't far behind. Too much difference between cylinders especially given that a wet test was done with similar results. Given that everything else is up to par (dangerous assumption), I guess that points torwards the valves and some work needs to be done. I am not sure a valve adjustment would help.
« Reply #2 on: December 22, 2011, 22:49:41 »
A cylinder leak test followed by a vacuum test would give a more reliable indication as to engine condition, but it doesn't look brilliant.
DaveB
« Reply #3 on: December 23, 2011, 03:35:38 »
Factory specs from the technical data booklet are: new 156-171 psi, minimum 128.
If that is the ebay UK car for £37,5k I think you can, eventually, find something better in Australia for a similar price (notwithstanding our recent car-chasing frustrations).
« Last Edit: December 23, 2011, 03:42:07 by DaveB »
DaveB
'65 US 230sl 4-speed, DB190
« Reply #4 on: December 23, 2011, 05:58:22 »
Hello Gary,
Try it with a warm engine, and a different compression gauge. I open the throttle also.
« Reply #5 on: December 23, 2011, 09:57:03 »
Hello Dave
I think there is a blue 280 for sale in WA. It has been up for a while. have you by any chance seen/inspected the car?
Hamid
