Author Topic: Source for air cleaner mount/rubber buffers  (Read 9378 times)
twistedtree
  • USA, MA, Gloucester
« on: January 04, 2012, 12:59:41 »
I need a bunch of these for my cars.  I'm missing several and others have broken.  Unlike the rubber buffers for the fuel pump which cost about $2 each, the typical sources list list these larger buffers as $35 each.  That really adds up when there are three per car, and 4 cars.
Does anyone know of an alternate source for these?  It doesn't seem they should cost more than a couple of dollars each.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
Re: Source for air cleaner mount/rubber buffers
« Reply #1 on: January 04, 2012, 14:34:26 »
Exhaust shops may be able to help e.g:
http://www.minisport.com/mini-spare-parts/info_GEX7251.html
Naj
merrill
« Reply #2 on: January 06, 2012, 00:22:14 »
I bought some from K&K a few years ago. they were not that expensive (then)
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
twistedtree
« Reply #3 on: January 06, 2012, 00:40:21 »
I just took a look and they don't list them any more.
I have found a couple of possible manufacturers of rubber parts that might be suitable replacements.  If they check out (which will take a while to do), would there be any interest in a group purchase?
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
Jordan
  • Canada, ON, Jordan
Marcus
66 230SL  Euro 4 speed
Tomnistuff
  • Canada, Qc, Levis
« Reply #5 on: January 06, 2012, 01:49:00 »
I just bought three of these from bimmerspecialist.com.  They were $2.20 Canadian.  They are in the U.S. but sell in Canada with Canadian prices as well.  And they take PayPal.  It's MB Part No. 116 988 05 11 .  They also ship Purolator and have lots of other vintage Mercedes stuff.
Tom Kizer
twistedtree
« Reply #6 on: January 06, 2012, 02:01:24 »
Found these on e-bay.  Are they correct?  Certainly cheaper than $35.
http://www.ebay.com/itm/1100940085-Mercedes-Air-Cleaner-Mount-190C-200-220-230-/120759379390?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1c1dd1e5be
Yes, I think that's the right part.  I've ordered one from MB as a sample.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
Jordan
« Reply #7 on: January 06, 2012, 02:30:12 »
Tom, I don't think the ones from bimmerspecialist are the correct mounts, they look like the ones on the fuel pump.  Compare it to the one on e-bay and you will see what I mean.
Twistedtree, how much is MB charging for a mount, or is this the $35 you quoted earlier?
Marcus
Marcus
Tomnistuff
  • Canada, Qc, Levis
« Reply #8 on: January 06, 2012, 02:37:12 »
Marcus, that Bimmer Specialist rubber buffer is a manifestation of my motto, which is, "I may be a purist, but I'm not a masochist!"  I'm the guy who bought heavier duty aftermarket urethane swaybar links for 1/10 the price of MB OEM.
Tom Kizer
twistedtree
« Reply #9 on: January 06, 2012, 12:50:32 »
From MB they are $20ish each.  It's still unclear to me whether all three are the same, or if the one on the bottom is different.  K&K says they are different, and the EPC says they are the same, but EPC also pictures a completely different air cleaner assembly than what a W113 actually has.
Once I have a sample and get back to my shop again (a week or so from now) I'll dig into this some more.  Normally I wouldn't spend the time for a $50 savings, but when you multiply that by 4 it starts to add up.  Plus it just kills me to spend 10x what something should cost when there are lots of manufacturers who make similar parts.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
Jordan
« Reply #10 on: January 06, 2012, 13:20:12 »
Yes, my parts book shows there are 3, all the same, part number 189 094 00 85.
Marcus
« Reply #11 on: January 06, 2012, 18:13:49 »
That p/n is replaced by 110 094 0085.
I have a hunch that Meyle is the manufacturer for MB and you can get it for about $10 - $12.
http://www.autohausaz.com/search/product.aspx?sid=klbrof554anms355byrkfe45&partnumber=1100940085
http://www.ebay.com/itm/120759379390
Although the spare parts list for a M130 engine shows that you need 3 I believe that this is a printing error.
On my 1968 280SL only two are required but one of them also needs a special bracket between the canister and the chassis wall; see: http://www.sl113.org/forums/index.php?topic=13814.
I believe the air canister for M127 engines (230SL) needs three double-threaded buffers.
twistedtree
« Reply #12 on: January 06, 2012, 18:29:01 »
Well, now I feel silly.  The part on Autohaus appears to be correct. The silly feeling is because I looked their first and when you look up by car make/model/year all they list are the buffers for the fuel pump which are smaller.  For me, the search is over.
Oh, and the reason there are three, not 2, is because there is one on the bottom of the canister.  Two on the sides, one on the bottom.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
Jordan
« Reply #13 on: January 06, 2012, 19:56:19 »
Twistedtree, I did the same thing and looked in Autohaus and only found the fuel pump mounts.  Thanks Alfred for the link.  My search is now also over. ;D
Marcus
Marcus
« Reply #14 on: January 06, 2012, 20:02:12 »
... Oh, and the reason there are three, not 2, is because there is one on the bottom of the canister.  Two on the sides, one on the bottom.
That is true only for your 230SL but not for the 280SL. That one has a rubber plug at the bottom; see photo. One red arrow shows where one of the two buffers attaches to the inner fender wall, the other identifies the plug.
I have also modified my previous post: http://www.sl113.org/forums/index.php?topic=13814   showing how the bracket is attached to the canister.
twistedtree
« Reply #15 on: January 06, 2012, 20:17:34 »
Interesting.  I'll have to check out my 280, but I presume it's the same as yours.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
glenn
« Reply #16 on: January 07, 2012, 17:28:03 »
I think VWs used a similar buffer.
Jkalplus1
« Reply #17 on: July 25, 2012, 01:57:05 »
Quote
I just finished replacing all three.  The 2 on the side were double-threaded, the one on the bottom was single-threaded, it was screwed to the canister and the rubber part sat there on the chassis.
I replaced with 3 double-threaded, since there was a corresponding hole for the bottom buffer in the chassis.  Car is a 64.
The part is different than the one Tom Kizer shows.  The rubber part has a waist, kind of like a hourglass, instead of straight.
Jerome
