Author Topic: How change dash lightbulbs?  (Read 3698 times)
Dave
« on: January 08, 2012, 18:46:02 »
My speedo and tach are dark.  Do I have to start at the glovebox, and take out the entire dash, or can I just get the speedo unit out to get access to the bulbs?  1967 230SL
Re: How change dash lightbulbs?
« Reply #1 on: January 08, 2012, 22:01:27 »
Dave,
Before going there check the fuse, No7 I think as it is unusual that all the lights go out together, then the second area for checking is in the dash area and whether an earthing wire has come loose.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Dave
« Reply #2 on: January 09, 2012, 14:33:30 »
Thanks Garry.
Unfortunately, fuse is good.  I had only one instrument illuminated for a while, not they are both dark.  Sawzall?
Ulf
« Reply #3 on: January 09, 2012, 15:19:09 »
Could also be the rheostat (the thingy that controls the brightness of the bulbs), bypassing it is covered in the technical manual and it took only 10 minutes :-)
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
« Reply #4 on: January 09, 2012, 17:04:13 »
As for order - generally, you start with the speedo, then the center cluster (not sure if you can get the bulbs without pulling it out - so you will need to be careful with the temperature gauge as it is all one piece and the oil pressure line which is directly connected to the engine) and then the tach. The removal and replacement have been covered a number of times on the forum. Use the search function and you will get the information you need. And about jumping the rheostat, there should be a number of pictures too.
