Author Topic: What have you done to your Pagoda today?  (Read 576896 times)
« Reply #575 on: May 12, 2016, 03:06:43 »
I can see how a beige/tan or brown one might be nice on my car, but I did not see any option other than black in the English language link that had been forwarded by a friend.  Turns out that she sent me a direct link to the black 113 windblocker.  However, after you mentioned the alternate color I logged on the site using the url on my packing receipt and find that it is offered in all-black and also beige/tan with black mesh.  To tell the truth, I'm very happy with the look of the all black one after seeing the photos.
I did find a handy accessory storage bag when trolling through their site that I might have to order!  Curiously enough, the site recommends a "Size 3" bag for the all-black windblocker and a "Size 4" bag for the beige/tan one.  I would assume that the dimensions would have to be the same for both 113 windblockers - any thoughts from the group on which size is actually correct?
« Last Edit: May 13, 2016, 14:02:56 by Mike Hughes »
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #576 on: May 15, 2016, 21:35:23 »
More like what I've done for my Pagoda ... yesterday :)
Got a garage mate for my Blue Tornado this weekend. I will call the addition The Red Baron it is a 230SL 1963 I say.
I will park The Red Baron in my office for a spell anyway ... until the shelf for my other little ones is on my cool garage wall :)
« Last Edit: May 17, 2016, 12:16:00 by Rolf-Dieter »
neelyrc
  • USA, AL, Birmingham
« Reply #577 on: May 17, 2016, 06:15:21 »
This morning we had beautiful May weather in Alabama.  My brother Harold was available to offer a hand so we backed the Pagoda out of the garage and removed the hard top for the first time in a good number of years. I wanted to check the condition of the soft top which had been in the “up” position only a very few times over the years.  In putting it up we found it nearly as stiff to stretch into position as when new.  We were pleased to find that the condition of the fabric was excellent, in fact it still looks practically as new. When in position there are a few wrinkles behind the doors on each side which I expect would stretch out if left in position a few days.  The only thing that appeared to have deteriorated was the folding-instruction decal in the roof well.  Although discolored, the multi-lingual decal can still be read after over 47 years!  A few pictures are attached.
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
neelyrc
« Reply #578 on: May 17, 2016, 06:18:17 »
More pictures for Post 577 above
Ralph
Italy
SnowWhite
« Reply #579 on: May 19, 2016, 23:50:32 »
Success with a Pertonixpoints installation...... ONCE I went back to the Bosch Red 030 coil.
I had installed the PerTronix Ignitor and their 40511 Flame-Thrower 40,000 Volt 3.0 ohm coil which crapped out at 4,000 RPM.  Like hitting a wall.
The Bosch 030 Red coil cured the problem and my 66 230SL now easily revs up to 5500.
« Reply #580 on: June 03, 2016, 16:51:49 »
This morning I started with a comprehensive review of all engine management systems, because yesterday the car was running very poorly (missing routinely at low rpm's). Started by printing the tech manual linkage tour (thanks again Joe ...) and proceeded with some basic things. First checking the air filter, to make sure no small rodents had taken up residence there during the long periods of inactivity over the past years. Then swapped out the spark plugs, even though they were fairly new, because the no. 3 had fouled up last week, when I changed the timing chain. Enriched the idle mixture two clicks, re-set the ignition timing, re-set the intake venturi air flap to 'binding'. Checked whether the rack in the FIP was free. I already knew the WRD was free and had adjusted the valves only 2 thousand kms ago, so those should be fine. So I did nothing methodical yet according to 'the Tour', just 'here and there' checks to rule out obvious things. Then went for a test drive and WOW the car has never run so strong and smooth. When the engine had fully warmed up, stopped by the side of the road and adjusted the air screw on the intake manifold to fine tune the idle to 750 RPM (car was running at 620). Later I went for a longer drive, some 100 km, to check whether anything had changed, but it's all great. I will still go through all the Tour steps, just to make sure, but couldn't be happier with how it runs now. I think replacing the timing chain has made a marked difference, so the engine timing (valves vs pistons) is now where it should be for the first time in many years. it's always nice when a bit of tinkering delivers such good results.
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
« Reply #581 on: June 06, 2016, 20:36:36 »
One day trip to the rhein river with the famous Loreley.
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
49er
  • USA, CA, El Dorado Hills
« Reply #582 on: June 06, 2016, 23:41:42 »
hello Peter, Very nice pictures along the Rhein. I have a photo taken in the exact same spot but only a VW Golf not a beautiful Pagoda in the foreground. Hope the flooding in France didn't come to you on the Mosel.
John
1969 280SL 003820
4 speed manual, PS. 77K+miles
7K+ miles since awoken from her 20+ yr "nap" in 2010
Peter h
« Reply #583 on: June 07, 2016, 06:00:46 »
Hallo John
In liddle more water  then usual.
Last weekend a group from the nederland with DKWs  stay at our hotel. Nice people nice cars and biks
mclewis
  • USA, NJ, Saddle River
« Reply #584 on: June 08, 2016, 13:45:05 »
Drove it for the first time in (8+?) months, for a whole 300 feet!  Just got my car back yesterday after having the head gasket replaced and the engine bay cleaned up a bit.  Hoping for a more extended drive this weekend.
Marc Lewis
1968 280SL 728H/728H, 248, 746
2020 C300
2021 E450 All Terrain
A-230
  • Norway, Akershus, Bærum
  • -64 230SL
« Reply #585 on: June 14, 2016, 17:57:11 »
I drove him some kilometers to the butcher, and drove home with raw sausages for the barbecue and a good feeling  8)
Drive safely,
Karl Kristian Bjørnland
-64 230SL -7403
-10 GLK300 4M
m300cab
  • USA, Pennington New Jersey
« Reply #586 on: June 15, 2016, 17:08:50 »
Good Times :)
Michael Parlato
Liquid silver
« Reply #587 on: June 16, 2016, 22:33:26 »
Have spent the last few days preparing my 230 for the MB National Concours
Jowe
« Reply #588 on: June 18, 2016, 17:59:29 »
Today, I participated in the Swedish Mercedes-club annual meeting, this year gathering on the Swedish west coast. Around 140 vehicles ranging from 1939 until today participated in a 70 km rally on nice curvy roads with pit stops for quiz and maneuverbility excercises and a final lunch. 9 Pagodas joined. Everything very well organized. Thank's Jonas et. al. I also convinced a few of the Pagoda owners to join our forum and not only sneak view  ;)
Johan
mbazinet
« Reply #589 on: June 19, 2016, 01:24:31 »
I managed to "annoy" my SL by stripping out the  #3 plug threads while doing what i thought would be a simple plug change ! Had to tap and Heli coil it to fix it .
i also while i was on a streak I managed to cause myself more grief  i was changing the fuel injectors and the cap on one of the injectors was frozen so as i was turning, i managed to twist the steel line and break it off.  So much for simple jobs today !
Pinder
  • USA, NJ, Edison
« Reply #590 on: June 20, 2016, 14:49:11 »
Over the weekend I cleaned out two Gas tanks and two fuel sending units. One of the fuel sending units ha the copper wire detach from one end so i soldered it back on and it worked nicely.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #591 on: June 20, 2016, 17:28:00 »
I just had my five wheels (original and date coded) cleaned up (rust removed) and powder coated.
They are not quite as smooth as the original paint, but I sure like how they look.
1998 BMW M-Rdstr Estoril Blue
« Reply #592 on: June 21, 2016, 00:12:38 »
I finished restoring my horns.
Iconic
« Reply #593 on: June 21, 2016, 13:06:18 »
Nice horns !
Montreal V8
« Reply #594 on: June 25, 2016, 04:25:28 »
 Fitted European lights today. I've always felt they "make" a Pagoda -personal preference, as I know they are  not universally liked. The car had  the side markers removed before I bought it. I removed the the bumper guards (ugly ?), fitted the chrome trim below (behind ?)  the license plate, so now, apart from the head rests, it looks like a European market car.   I know, I know  -- the purists may throw their hands in the air, but I think it looks fine. Comments, pro and con, welcome.    Cheers,  Dale.
« Reply #595 on: June 25, 2016, 05:43:59 »
I've always thought that, because Mercedes designed the car originally in European spec, and then later had to 'federalize' it, I liked the original euro design best. That's why I did like you to my American delivered Pagoda. So good for you! Actually I don't recall having seen much support for the 'keep it American' approach.
Montreal V8
« Reply #596 on: June 26, 2016, 19:33:41 »
Thanks for your comments, Cees.  I'm certainly very pleased with the installation, looks great.    Cheers,  Dale.
« Reply #597 on: July 01, 2016, 10:27:40 »
Finished painting my gas tank
Liquid silver
« Reply #598 on: July 12, 2016, 23:36:51 »
Got a Notice of Intended Prosecution for speeding. 36mph in a 30mph zone.
Tomorrow having new rear bearings fitted.
Bullethead
« Reply #599 on: July 17, 2016, 23:30:56 »
Adjusted (sort of) the windshield wipers which I didn't do prior to assembling the dash. With the AC unit in place it's a PITA,
and to top it all off, the left wiper sweep is perfect, but the right stops at the vertical. Any suggestions?
My guess is I did something wrong with the mechanism before it went in.
