Author Topic: What have you done to your Pagoda today?  (Read 516843 times)
merrill
« Reply #850 on: June 14, 2019, 16:58:05 »
Finally was able to pull the rear axle out today,  it took a few weekends to make it happen.
overall about 7 hours total
now to replace
pinion seal
klunk bushing
rubber axle bellow
both rear axle bearings and seals
i also will be sending my shoes and drums out for re lining
6 more hours today,
pulled hanger and had to beat out what is left of the old klunk busing (photo)
installed new pinion seal
tore down brakes on both sides
removed both brake cylinders
removed all bolts holding the backing plate in place
decided to give up when the backing plates would not come off
only a few more hours in today
pulled both axles using the 3/8" threaded rod method,  it worked
remove the lock plates and nuts securing the bearings
could not get the wedge bolt off the axle to separate the swing arm from the rest of the axle
nor could i knock off the bearings using by taping the end of the axle on a block of wood.
1 trip to Home depot for 3/8" rod and then  a trip to harbor freight for a bearing puller set and back to home depot for 2' long 3/8" rod so can pull the bearings.
i hope to make more progress tomorrow.
well short day today
wedge nut is out, the threads are ok but the threaded portion is bent,
and pivot rod is out thanks to advice from Joe A.
another 4 hours in today
removed and installed axle and backing plate seals both sides
removed and installed new bearings after a hand packing with mobile 1 both sides
installed drivers side axle
july 3
2 more hours today,  aligned swing arm with all washers , bushing etc in preparation for installing the pivot rod tomorrow
july 4
5 more hours today, installed pivot rod, wedge pin, swing arm drive shaft and bellows with clamps
july 6
rear end is in, compensating spring installed, centering bracket connected and shocks connected.
lets see if i can finish this up tomorrow...
« Last Edit: July 06, 2019, 23:55:07 by merrill »
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #851 on: June 23, 2019, 00:28:36 »
Getting close to being done under here.  Only a couple more days.
Por911t4
« Reply #852 on: June 23, 2019, 07:59:36 »
I did nothing more than drive it top down in the sun, collected flowers and admired the sunlight hitting the dash .... simple pleasures .
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
« Reply #853 on: June 23, 2019, 09:44:07 »
I work at the heater ventil. Easy doing, maybe 20 minutes or so.
Now they work very soft and perfekt.
« Last Edit: June 23, 2019, 09:53:32 by Peter h »
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
« Reply #854 on: June 23, 2019, 12:52:04 »
Peter,  Glad you were able to pull it so easily.  They can be very tough to remove.
A-230
  • Norway, Akershus, Bærum
  • -64 230SL
« Reply #855 on: August 19, 2019, 20:01:43 »
I had it checked for the bi-yearly technical control we have here in Norway. Approved for another two years.
Drive safely,
Karl Kristian Bjørnland
-64 230SL -7403
-10 GLK300 4M
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« Reply #856 on: August 19, 2019, 20:56:34 »
Tracked down a coolant leak to the new pipe that I installed (was missing before; was just straight hose) that goes under the intake manifold runners.  Loose worm clamp.
Tightened down the Frigiking.  One side came loose (hole stripped?) while driving so as a passenger, wedged my foot there until we got home.
Drove downtown seattle!
MikeSimon
  • USA, OH, North Royalton
« Reply #857 on: August 20, 2019, 00:47:04 »
What??? And it wasn't raining? I thought the Seattle Rain Festival that usually goes on from Jan 1 through Dec 31 was in full swing... :P
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
teahead
  • aka "Rob"
« Reply #858 on: August 20, 2019, 06:04:21 »
We get 3 months/year that's lovely.  Otherwise it sux.
MikeSimon
« Reply #859 on: August 20, 2019, 16:22:13 »
 ;D ;D In spite of all this, I love Seattle. My favorite eats used to be the Zabaglione dessert at "13 Coins" (restaurants may be closed or changed) fresh Copper River salmon during the few weeks it is available end of May/early June at any place at Lake Union, a good steak at the Metropolitan Grill and hanging out at Pike's Place...and playing the game of never losing sight of a Starbucks shop  while walking from Pioneer Square to Pike's Place. :o :o
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #860 on: August 30, 2019, 02:27:36 »
Just another day restoring things no one will ever see.
teahead
  • aka "Rob"
« Reply #861 on: August 30, 2019, 03:23:23 »
Very nice nonetheless.
As aforementioned in the other thread, installed a 123 ignition
« Reply #862 on: August 30, 2019, 18:27:23 »
I got to unwrap my grille from it’s 10 year old newspaper.  That felt good.
sbarouch
« Reply #863 on: September 01, 2019, 18:09:54 »
Finally finished installing my new Timevalve SS exhaust.  I had Mike weld in two bungs so I can measure air/fuel ratio.
« Reply #864 on: September 01, 2019, 18:37:32 »
I ran a sponge over mine in prep for a trip next week to Goodwood Revival ;D
« Reply #865 on: September 03, 2019, 01:33:42 »
The tedious task of masking and painting hubcaps. With factory feathered look.
« Reply #866 on: September 03, 2019, 01:44:48 »
After my long trip i have to do mine again, they have taken a bit of a battering in the last 8000 miles in the two months.
Those look good.  Did you put on an etching paint first up.
« Reply #867 on: September 03, 2019, 02:40:08 »
Garry, Yes sir. The chrome is brand new so gave it a key with scotchbrite. Then a coat of drab based self etching primer (2nd pic). I was going to clear them but I'm sure I’ll be doing them again at some point.
merrill
« Reply #868 on: October 13, 2019, 21:50:08 »
took my 66 230 for a drive for the first time in 3 months today.
after i completed the rear axle work it got too hot in TX to drive.
today was a nice day so i took her for a drive,  I received lots of compliments and 3 folks asking if I would sell it.
« Last Edit: October 14, 2019, 13:37:19 by merrill »
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #869 on: October 21, 2019, 01:02:37 »
I really like the way Ralph's 280 looks with those 3/4 WW Maxxis tires so I had a set of 185/75s mounted over the weekend. They ride really nice and I think they look great.  Achim, that right front wheel may look familar  ;)
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #870 on: October 21, 2019, 02:39:03 »
Just took her for a spin today along country roads .... felt guily having neglected her while traveling too and from PagodaFest. Temperature in London, Ontario today was 20 C
Dieter
neelyrc
  • USA, AL, Birmingham
« Reply #871 on: October 21, 2019, 15:38:32 »
They look really great!!  :D
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
49er
  • USA, CA, El Dorado Hills
« Reply #872 on: November 07, 2019, 17:42:20 »
 Actually it was this past Sunday that my Navigator and I put the top down and took off for a nice two hour drive. It has been a while since we have had an opportunity to get out out and enjoy our car due to Medical issues (which have been resolved), four power shutdowns (for fire prevention), oppressive heat and smoke from distant fires . As always the car ran great and the new battery got it started on the first crank. We are still "not out of the woods" here as the threat of fire (and loss of power) continue until we get some much needed rain but as long as the weather stays nice, we intend to get in a few more rides before those rains show up.
John
1969 280SL 003820
« Reply #873 on: November 10, 2019, 07:27:46 »
I watched a thing on the "camp" fire (Paradise) on TV recently. The speed of that thing - it's amazing more didn't lose their lives. Go carefully....
wayne R
« Reply #874 on: November 10, 2019, 13:02:57 »
John
Hi John,yes i know what you are talking about those  years  i living in Sacramento,
Placerville  has alot of wooded areas, hope you,  family , and pagoda,have agood  exit plan ,if ever you have to
get out up there in the hills.
WE used to love the drive from the valley to lake tahoe alot,probably went past your area about 6 times every year.
Regards Wayne.
« Last Edit: November 10, 2019, 23:22:14 by wayne R »
