Author Topic: What have you done to your Pagoda today?  (Read 525746 times)
mario
Re: What have you done to your Pagoda today?
« Reply #525 on: March 02, 2016, 15:37:22 »
Visited my pagoda at the restoration shop yesterday.  Next week will mark one year that the car has been away.  The shop has done a tremendous job in bringing this one back to full beauty.  I counted at least 9 pagodas there yesterday along with a couple of 190s.  I hand carried new headlight doors on the plane with me to deliver to the shop.  The few things that remain include new carpet and seat coverings.  The dash needs to be put back together and am installing A/C.  I found an original Frigiking unit that is being restored as well.  The car did not come with A/C originally, but our summers in S. Louisiana are brutal.  When I bought the car it was a strange shade of almond.  The car was originally tobacco brown with cognac interior.  After months of deliberating of whether or not to go back to original, I finally decided on 172G Anthracite Grey Metallic.  The interior will remain Cognac.  A few pics are attached.  The headlight doors in the pics are the old ones.
« Reply #526 on: March 02, 2016, 15:44:49 »
Awesome color combination. Car is looking great!
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #527 on: March 02, 2016, 16:02:11 »
Mario, Nice job, you must be a happy camper once she is all done :) looking great!
Dieter
« Reply #528 on: March 02, 2016, 19:19:01 »
Gorgeous!
1972 Lancia Fulvia Coupe 1.3
mario
« Reply #529 on: March 02, 2016, 20:00:35 »
Thanks all for the comments!  Picking the color was a difficult choice but I'm very happy with it.  You may recall the workshop from this thread:
http://www.sl113.org/forums/index.php?topic=21649.msg154173#msg154173
I know several of you have had your cars looked after by Gus.
Milly
« Reply #530 on: March 08, 2016, 23:39:31 »
How about what I did to my Pagoda over three winter. Where do I start? Well here goes. I replaced the full exhaust front to back,replaced transmission mounts, motor mounts, radiator,all hoses,fuel pump fuel lines, fuel filter,front shocks,transmission fandango differential fluids. I am hoping for a trouble free summer and a lot of driving.
mario
« Reply #531 on: March 09, 2016, 18:11:50 »
Busy winter Milly!  Car looks great!
Rolf-Dieter ✝︎
« Reply #532 on: March 09, 2016, 22:56:22 »
Car looks super Milly😊 See you on the road.
Mario, that would be three long winters here in Canada 🤓
49er
  • USA, CA, El Dorado Hills
« Reply #533 on: March 18, 2016, 16:58:29 »
 Drove the Roadster down to Ernies for her annual check up yesterday and she passed with flying colors. Oil/filter change along with the fuel filter being replaced and happy to see no sediment in the filter's bowl. Always a bit of a white knuckle experience driving down to the Big City (Sacramento) but we both made it down and back unscathed ;D
PS Always liked the to call my car a "Roadster" as that was what Mercedes called it, a "Coupe Roadster". I really don't remember anyone using the term "Pagoda" back then.
1969 280SL 003820
« Reply #534 on: March 19, 2016, 06:21:07 »
The 'Pagoda' term I'm pretty sure was only used outside of North America until we started using it here in this group. I remember an exchange like this where it was Doug Kim in New York who suggested 'why not adopt it also in the US' or something to that effect, and since then it has stuck. Just like David Pease coined the 'BBB' term at some stage of our development.
su8pack1
  • USA, PA, Barto
« Reply #535 on: March 19, 2016, 18:16:39 »
After installing new injectors and having it run much better, the warm up was still pretty rough with a lot of back popping. After it was warmed up and seeing the plugs were much cleaner it ran fine. I had also installed a new CSV which was working fine, fuel pump and fuel lines were done a few years ago, as well as a fuel tank flush. After researching this site and others and talking to several experts I pulled the injection pump and sent it out for a rebuild. Two months turn around time. I think my biggest problem is that it just sat for about 6 years up until a couple years ago and it's been a slow process to get it back right, doing the least expensive repairs first.
1984 300CD
1987 190E 2.6
1988 190D 2.5
StevenF
  • USA, NY, Merrick
« Reply #536 on: March 19, 2016, 18:26:26 »
I posted pics on this link:
http://www.sl113.org/forums/index.php?topic=23699.0
Since the summer of 2015...
Mechanicals: Engine sent out to Metric for rebuild.  Radiator repaired ,new water pump, thermostat, hoses, belts and all that goes with it...replacing bushing in shifter.
Interior: sent out tach & speedometer for reconditioning, sent all interior pieces for recovering,--keeping original carpet
Installing 3 point seat belts
Exterior--new paint, new windshield,new antenna,new seals,new hood badge etc
Still more work ahead...
1971 280sl
Red Metallic
Bamboo MB Tex
Montreal V8
« Reply #537 on: March 20, 2016, 18:35:46 »
    Not exactly today, but ---     When I bought my late 280SL, it had a 123 distributor, emission control inoperative, no vacuum line to dist., and 123 set to E. It ran quite nicely, but I had no previous            experience re. the performance.  As the emission stuff was inoperative, I removed it in it's entirety, including the wiring. That sure improved the under hood appearance !  After reading a lot of information on the Forum  I decided to look for an earlier throttle body, and was fortunate enough to find a perfect one, installed it, hooked up the vacuum, set the 123 to curve #8 , and  Wow !!
  Timing advance is now correct, with 38 degrees at just below 3000 RPM. The two immediate improvements were much better starting, and a considerable improvement in mid range performance. The car now run up slopes/hills without having to shift down, as previously, although I can still occasionally botch a hot start. The idle runs consistently at 550, which is also a nice gain. Haven't checked fuel mileage (If I couldn't afford the fuel I couldn't afford the car)  but as Dan (Benz Dr) said in a previous post the performance  is a noticeable improvement, so mileage is a secondary, almost unimportant, consideration. Hope this may be of interest to owners of US spec cars running  the 123.
Jowe
« Reply #538 on: March 24, 2016, 19:20:43 »
Today, I wakened the beauty from winter hibernation an took it out for a spin. What a joy! Now the fuel pump was humming nice instead of being very noisy. (See http://www.sl113.org/forums/index.php?topic=23329.0 ) Back at home I re-torqued the engine head bolts (thank's for the valuable PUB session on that topic) and was also supposed to adjust the valves. But I found to have the wrong wrench so need to postpone that work a few days. The timing chain was firm on the sprocket. A good sign, I guess. I will examine the cam lobes for wear as well.
Johan
RobSirg
« Reply #539 on: March 25, 2016, 12:41:35 »
My Engine Rebuild is coming together quickly now and looking good. So happy with my choice of rebuilder (Greg Wood) - he is taking such care and precision. Quite convenient that his Shop is about 1 mile from my home. Got to move the crank yesterday - silky smooth.
First photo is how the block looked when I gave it to him and it cleaned up a gem  - you can see the red overspray inside after cleaning. Pistons cleaned up well. We went with new rings, chain, cam (lobe showed evidence of weld), rockers, etc, - everything else was rehoned, regound, straightened back to original specs.
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
RobSirg
« Reply #540 on: March 25, 2016, 12:43:49 »
A few more
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
RobSirg
« Reply #541 on: March 25, 2016, 12:45:24 »
last one
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
StevenF
  • USA, NY, Merrick
« Reply #542 on: March 25, 2016, 18:17:30 »
A few updates as of today
1971 280sl
Red Metallic
Bamboo MB Tex
RobSirg
« Reply #543 on: March 25, 2016, 23:33:55 »
Love the colour Steven (I'm a sucker for the less common / 70's colours). Is it the original colour? It will look great with the Bamboo interior.
Nice shut lines on the hood.
Mine is getting there ......ever so slowly (why oh why did I tell him I wasn't in a hurry ???)
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
su8pack1
  • USA, PA, Barto
« Reply #544 on: March 26, 2016, 00:14:55 »
I put in new motor mounts today. I'll do the transmission mount this weekend.
1984 300CD
1987 190E 2.6
1988 190D 2.5
StevenF
  • USA, NY, Merrick
« Reply #545 on: March 26, 2016, 15:26:01 »
Rob,
Yes--original 571 red metallic.  It is a very interesting color.  I can't wait already....the weather in NY is getting nicer...finally!
Steven
1971 280sl
Red Metallic
Bamboo MB Tex
Pinder
  • USA, NJ, Edison
« Reply #546 on: March 27, 2016, 02:28:24 »
Paint is looking great Steve
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
RobSirg
« Reply #547 on: March 29, 2016, 01:18:24 »
Engine is getting close now :)
« Last Edit: March 29, 2016, 01:23:17 by RobSirg »
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
Rolf-Dieter ✝︎
« Reply #548 on: March 29, 2016, 01:47:06 »
Rob ... Wow is all I can say ... She looks fantastic 😳
68_white
  • USA, TX, Houston
« Reply #549 on: March 29, 2016, 02:39:20 »
I just saw Mario's car today, while I was getting an oil change.  All I can say is wow. Congrats Mario. Not much more work left. Gus has been maintaining all three of my lucky stars for many years.
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
