Author Topic: 3.27 ratio rear differential  (Read 4010 times)
naniroma0
« on: January 24, 2012, 23:34:04 »
hello,
Are they equal the crown and pinion `treasero group of 107 and a pagoda?
Don ¿is a 3.27 ratio for sale?
Re: 3.27 ratio rear differential
« Reply #1 on: January 25, 2012, 18:53:17 »
I THINK the question is:
"Can I substitute an differential from a 107 with mine?"
IF my assumption is correct then no you cannot. (At least, not without some serious modification!)
« Reply #2 on: January 26, 2012, 02:07:12 »
The W107 rear axle is completely different.  The W107 rear suspension has live rear axles,CV joints and a three piece sub frame assembly which includes two trailing arms.
naniroma0
« Reply #3 on: July 21, 2012, 23:27:17 »
OK,
thanks
