Author Topic: 280 sl wing repair  (Read 2659 times)
piers
280 sl wing repair
« on: June 04, 2004, 05:45:52 »
Wanted advice on how to change a front right wing on a 280 sl pagoda. Many thanks,
Piers Fitz Gerald
piers fitzgerald
Re: 280 sl wing repair
« Reply #1 on: June 04, 2004, 06:15:22 »
Piers,
I don't know if you have received any information on this, but I can tell you it is a bit of job I'm afraid.  I believe there's welding involved!  That's enough to scare me right into the shop of a professional[:0]
Most of this group does mostly mechanical repairs, and major body work is not something the average 113 owners does, and if they do it, perhaps only once :)
To get an overview and possible pricing, you should contact K&K; they supply a lot of sheet metal and might have an idea of what it takes to solve your problem.  My own experience indicates you should forget the email and call them directly; you will end up speaking with Cheryl, the queen of sheet metal!
You can reach them at http://www.kkmfg.com/  Tim Kidder is great guy, and they supplied all the sheet metal (don't ask!) used in my restoration.  Best of luck!
