I wonder how many other late 250sl and 280sl,s have manual steering ??
I say this because my late 250sl is a manual steering car and i know jack jones 280sl is the same...there must be at least a thousand others out there of the thousands made which did not go for the power steering option back in the day!! they will have the "stealth steering shafts" just ripe for conversion ?
I am not recomending that people should rush out and do this ,its just that i like to set myself little chalenges, to see whats possible, and find the easiest way of doing it ! like i said before " it may not work out but all evidence points to it working......
Heres where i am with this !
After convincing myself (through drawings and advice on this forum) that i had the telescopic (stealth) shaft i bought a power steering box ,pump and fittings from a nice chap with a donor 280sl .
I did not buy the column and shaft as i convinced myself i did not need it ( come on ,be positive )
I started to remove the engine yesterday and had it out by 7 in the evening (i left the 4 speed gearbox in the car) i will remove this later when i put the car in the rotisserie jig .
Anyway i am at work today but this evening or tommorow (SAT) morning i intend to stand in the engine bay, remove the manual steering box and coupling and
give the bottom end of the shaft a good tap and see what happens, i will use the guide holes in the upper column to give me the required length.
I will let you all know what, "if anything" happens....wow ,how sad am i !!!
Is it just me.......dont answer that ...
