Author Topic: Need help finding original Clamp fixings to Trunkfloor  (Read 7786 times)
450sl
« on: January 31, 2012, 14:56:33 »
Hi All,
Helping out a friend , with an unfinished 71-280 trunk, but he does not have any records on how the Jack-Clamps were fixed to the Trunkfloor .
Anybody willing to share a Detailed-Picture of the mountingplates , so i can help him making some new ones?
Attached an picture of the clamps
Mark
Re: Need help finding original Clamp fixings to Trunkfloor
« Reply #1 on: February 01, 2012, 16:42:59 »
Hi, Mark,
Hope this one helps
Naj
450sl
« Reply #2 on: February 01, 2012, 19:50:41 »
Excellent Naj, Thanks a million, this helps alot.
On your picture under the small Clamp ,i see a U-shaped  Bracket welded to the Floorpanel .
Could you just tell me how high it stands (from the Floor to the bottom of the Clamp) ?
Thanks again
Mark
« Reply #3 on: February 01, 2012, 21:05:47 »
Hi, Mark,
Thought you might ask that!
There is maybe a 1mm gap under the clamp.
This is not my car. Just one I saw today while visiting a friend's car. So I can't take any measurements.
Naj
450sl
« Reply #4 on: February 02, 2012, 11:46:54 »
Oke. thanks anyway Naj.
Anybody else prepared to take some measurements?
450sl
« Reply #5 on: February 09, 2012, 15:49:40 »
Really nobody with a 70 or 71 280Sl  willing/able to take measurements ??????
Even only the height of the U-bracket would help a lot to get as close to original..
Mark
twistedtree
  • USA, VT
« Reply #6 on: February 09, 2012, 18:10:56 »
I'm about 12,000 miles away from my car, otherwise I'd be happy help  ;)
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
hkollan
  • Spain, Castilla-La Mancha
« Reply #7 on: February 09, 2012, 20:39:17 »
Hello Mark,
It's around 30 millimetres on my 71 280 sl measured from the bottom of the U to the top of the bracket.
Hans
« Last Edit: February 09, 2012, 22:17:01 by hkollan »
Hans K, Cuenca, Spain
450sl
« Reply #8 on: February 11, 2012, 10:41:06 »
Thanks Hans
Do You know if the clamp is riveted to the u bracket or screwed?
Mark
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #9 on: February 11, 2012, 11:34:11 »
You can still get the clamps from the classic center I think.  Then just weld them in.  They should be cheap to buy.  I may have a few new small ones for the lug wrench.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
« Reply #10 on: February 15, 2012, 15:25:16 »
Hi, Mark,
The spring clip is riveted to the floor bracket.
The gap under the bracket is for the rivets.
I think the best way to lacate the bracket is to place the jack/rubber mat in position.
Hope these pics will help.
Naj
450sl
« Reply #11 on: March 03, 2012, 15:05:38 »
Thank You very much Naj , this is what i needed !!!
« Reply #12 on: March 04, 2012, 23:46:29 »
I think by the term'' rivets '' you are talking about spot welds?
Re: I think by the term'' rivets '' you are talking about spot welds?
« Reply #13 on: March 05, 2012, 09:32:40 »
Hi, Dr,
One can see 2 rivet heads in the gap in the spring clip.
Funnily enough, the bracket is spot welded on one of the panels (left in the picture above) and arc or mig welded on the other! We noticed this one three of the cars that were in the body shop that day.
Naj
« Last Edit: March 07, 2012, 12:02:37 by Naj »
« Reply #14 on: March 05, 2012, 17:32:47 »
So the spring clip is riveted on to the bracket and the bracket is welded to the floor. Vey anal stuff, when you think about it. :)
