Author Topic: Injection pump and pressure regulator connections  (Read 2559 times)
Ron
  • USA, CA, Arroyo Grande
« on: February 01, 2012, 02:02:43 »
Hi, I'm finally putting the correct 230SL injection pump onto my 230SL.  At present it has a 250SL injection pump, and the piping is a bit different.  From what I gather from the SLS page:
http://www.sls-hh-shop.de/index.php/language/en/cat/c3_Mercedes-Benz-230SL-250SL-280SL-Pagoda--R113-W113-.html#cat_58_position_57_prod_0
The fuel from the tank pump goes first to the fuel filter -> injection pump back connection (flare) -> through injection pump body -> injection pump front connection (banjo) -> center of pressure regulator -> side of pressure regulator to return to tank.
Do I have this correct?
If so, I'm missing the banjo (hollow) bolt (57) and female banjo fitting with pipe that is not labeled but connects to hose 58, which I have.  Anyone have that pipe and banjo bolt they could sell?
BTW, the front connection (female banjo) is labeled "overflow valve" and I wonder if that is a second pressure regulator in the system?   Ron
1966 230SL, euro
