Author Topic: I need HELP! I think it's the Starter!  (Read 2665 times)
mcreasy
« on: February 12, 2012, 13:56:25 »
I took my car out for a drive after sitting for several months...It started like a dream..drove around for a couple of hours and stopped at the store...drove home and parked it in the garage. The next day went to drive it and turned the key nothing. No click ...no sound ..nothing. I didn't think it was the battery but it was the most obvious so I put on charger and green light showed up in a few minutes. Try to start and nothing/ I assume it is the starter. I tapped it a little and still NOTHING!! What is your best guess OH WISE ONES!! I need words of wisdom from everyone before I replace the starter? Thanks
Re: I need HELP! I think it's the Starter!
« Reply #1 on: February 12, 2012, 14:42:10 »
Sounds like bad cable connections going to the battery or possibly a bad neutral safety switch cable going to the auto trans.  Try turning the headlights on and then try to start it. If the lights go out, then it is most likely the cable connections at the battery. If your battery cables have replacement ends, take them off and apart and clean the clamp connections. Try again, if the head lights stay on bright then it can be the starter or the neutral safety switch cable. To check the switch cable move the shifter up and down the range and watch the switch on the firewall for movement. Be careful a malfunction of the cable could allow the car to start in gear! If this seems ok, the starter may be at fault. You can activate the starter directly by running a small jumper wire(positive) directly to neutral safety switch plug. Pull the plug off and touch the jumper to the purple wire (top or bottom end socket). If yours is a standard transmission you can also jump directly to the starter by touching the (positive) directly to the "G" (small screw) on the thermal time switch.
If you still have no luck, check the wire connections at the terminal block on the right side of the  oil pan, then the connections at the starter.
Keep us up to date!
