Author Topic: WRD insulation  (Read 2962 times)
glenn
WRD insulation
« on: February 12, 2012, 17:20:05 »
Has anyone insulated the WRD coolant line from the head and the WRD thermo housing itself- to make sure hot, 200+ coolant gets to the WRD???....
Re: WRD insulation
« Reply #1 on: February 13, 2012, 23:55:16 »
Hello Glenn,
I suspect it is all relevant. The engine thermostat should maintain the temperature in the system whether the heat loss is at the radiator,cabin  heater, the WRD pipe or anywhere else in the cooling system.
glenn
Re: WRD insulation
« Reply #2 on: February 14, 2012, 03:01:09 »
Joe, Re: WRD    Have you ever put a washer under the snap ring inside the WRD slide valve?  If so, where did you get it?
twistedtree
  • USA, MA, Gloucester
Re: WRD insulation
« Reply #3 on: February 14, 2012, 03:44:38 »
I'm not Joe, but when I needed to add them I just dug around in my washer pile until I found something suitable.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
Re: WRD insulation
« Reply #4 on: February 14, 2012, 05:24:35 »
Hello Glenn,
Adding a shim here shuts off the air valve sooner.  Here is a source of metric shims ..............................................   http://www.mcmaster.com/#standard-metric-shims/=g8mzy2
