Author Topic: Bracket for holding air cleaner onto car body  (Read 4630 times)
rutger kohler
  • New Zealand, Auckland, Auckland
« on: February 15, 2012, 07:08:32 »
I am re-assembling my engine bay after detailing it.  I can figure out how the brakets go together where the air cleaner body bolts onto the inside of the mudgard (fender) Could someone plse post a picture of this.
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
Re: Bracket for holding air cleaner onto car body
« Reply #1 on: February 15, 2012, 12:43:37 »
These any help?
The bolt that goes thru the inner fender has a grommet and spacer tube which protects the rubber from being crushed.
Don't ask for the part # of the grommet  :'(
Naj
« Reply #2 on: February 15, 2012, 16:51:36 »
I just replaced that fender well grommet on m y 280 SL, but did not get the part number. You can check with Dave Gallon (member on the site) and he should be able to get the number for you. I have another coming for my 250 SL, so if no-one else answers I will supply it later.
« Reply #3 on: February 15, 2012, 17:48:09 »
Rutger,
this thread has additional photos of the grommet:
http://www.sl113.org/forums/index.php?topic=13814
« Last Edit: February 16, 2012, 01:33:07 by 66andBlue »
« Reply #4 on: February 15, 2012, 21:53:54 »
The part number for the grommet at the inner fender is
000 997 87 81
In the pictures set from 66andBlue, the top right photo is the connector for the air cleaner to the shroud protecting the air cleaner from the engine side.
« Reply #5 on: February 16, 2012, 01:29:19 »
Hello Jon,
good catch. The red arrow in my photo next to the buffer is misleading, since the buffer is not used to fix the canister to the inner fender. I removed the photo and replaced it with a better one, I hope. However,  this arrangement is not correct for the 230SL air cleaner canister!
rutger kohler
« Reply #6 on: February 16, 2012, 07:54:05 »
Thanks guys, great, apart from the fact that I dropped the bracket and have to pull the air cleaner apart and out again, to recover it!!
1972 280SE 3.5 auto
« Reply #7 on: February 17, 2012, 08:28:28 »
000 997 87 81
Thanks for the part #, JB
Naj
