Author Topic: Antifreeze change and acid level (pH) of fluid  (Read 3147 times)
IXLR8
« on: February 15, 2012, 19:00:41 »
Hi--
I have read that the anti-freeze should be changed every few years, but I have also read that the anti-freeze characteristics are pretty stable.
What necessitates the fluid change is the increasing acidity of the fluid over time. In other words, the bi-annual change rule is driven by corrosion concerns, not by the anti-freeze being ineffective.
I just now tested my anti-freeze with litmus paper and found it has a pH of 9; that is, well below the neutral level of seven and the start of the acid level of six.
Should I change the anti-freeze anyway, or just continue to monitor it for acidity?
The other Joe
PS, 80 litmus strips for 99 cents on eBay, free shipping!
Re: Antifreeze change and acid level (pH) of fluid
« Reply #1 on: February 15, 2012, 20:04:57 »
Other Joe,
Do you know what kind of anti-freeze you have in your car now?  The pH makes more sense when compared to the factory specification for the formulation, and changing according to the product specifications.
