Author Topic: rocker arm replacement  (Read 3021 times)
KenBourque
« on: February 25, 2012, 21:34:56 »
On a '70 280SL, is it necessery to also replace the pivot ball when inserting new rocker arms?  How can you determine if the ball  needs replacing?  I will be replacing the cam shaft.
« Last Edit: February 25, 2012, 21:59:05 by KenBourque »
Re: rocker arm replacement
« Reply #1 on: February 26, 2012, 00:41:00 »
Ken,
check the search feature, and Pagoda Notes. We just did a feature on the head reconditioning and it speaks to some of the issues with the ball studs.
George Des
« Reply #2 on: February 26, 2012, 13:43:27 »
I agree, check with the search function. I can tell you though in my own case when I did my rebuild, the original ball stud heads had developed a sharp feather edge on the balls. I thought it best to just go ahead and just switch them out for new ones while in there lest these old ball heads cause uneven wear on the new rocker arm mating surfaces. You may even find it difficult to adjust the valve clearances properly unless you do the change out.
