Author Topic: Brake fluid leak MC / Booster  (Read 2986 times)
rosch
« on: March 05, 2012, 09:15:02 »
Since a couple of months I experience some brake fluid dropplets  hanging at the bottom of the ATE brake booster of my  230 SL.
It's hard to determine where its leaks. Only a few drops in a couple of months. Usually after a longer period of stand still.Is this normal ?
Brake line  and resevoir connections at the MC are checked and apear free of leaks So I 'm concentrating now on the connection of the MC and the ATE booster.
Could it originate from a leaky O-ring between MC and booster ? And where does the oil coming out of via the small leak hole come from ?
Any suggestions or tips are appreciated.
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: Brake fluid leak MC / Booster
« Reply #1 on: March 05, 2012, 09:50:13 »
I had some brake fluid in the same area.  I replaced the master cylinder and this corrected the problem.  It seemed to be coming from the seal at the back of the master cylinder.  I have had no leaks since.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
« Reply #2 on: March 06, 2012, 00:35:56 »
Yes,
Most often the master cylinder has begun to leak. You will also find quite a lot of fluid has ended up in the booster itself. Some fluid eventually escapes and leaks down the booster under the master cylinder.
rosch
« Reply #3 on: May 16, 2012, 23:17:55 »
Master cylinder was checked OK .Bought a repair kit with new seals. Problem solved !
