Become a
Full Member
Emergency Contact List
Electrical and Instruments
spark plug leads
Topic: spark plug leads (Read 5672 times)
natenate
spark plug leads
March 05, 2012, 17:20:24 »
Hi im trying to buy a set of spark plugs leads for my 1967 230sl. somebody told me that euro parts do a beru replacement. but when i phoned them and gave them my reg number they can not find the part number. does anyone have any idea what the part number is??
regards
Nathan
Associate Member
Platinum
Canada, ON, Port Lambton
Re: spark plug leads
March 05, 2012, 23:49:42 »
A proper Beru set is available. I can't tell you what the part number is and it's very likely there isn't a MB part number for this set.
Most of the Bosch replacement sets I've seen have been wrong on several fronts:
carbon core coil wire
resistors on the wire ends
improper spark plug terminals with 90 degree ends
2K or even 5K spark plug terminals
Proper 230SL set should have no resistors on wire ends except for spark plug terminals with 1K ohms.
Spark plug terminals are bakelite without metal shields.
All spark plug terminals are straight for 113 style engines.
No carbon core wires.
About $65.00 for the set if I remember correrctly.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
franjo_66
Full Member
Silver
Australia, NSW, Point Piper
Reply #2 on:
March 06, 2012, 03:18:35 »
I just bought a proper OEM style set made by Karlyn for my 230SL. Only cost me $33 from
www.autohausaz.com
Link to the product details as follows:
http://www.autohausaz.com/search/product.aspx?sid=wflzzd455ay1ov3eop0hal55&makeid=800016@Mercedes&modelid=1342729@230SL&year=1965&cid=25@Ignition
Parts&gid=7228@Spark Plug Wire Set
I bought these for all the reasons listed by Dan (ie proper coil wire not carbon, no resistors, etc). These plus the 123 Distributor and red Bosch coil have made a profound difference to the engine performance.
Regards
Franjo
Franjo
1965 230SL Black/Auto/RHD
2005 Porsche Cayenne Turbo
1983 BMW 735i
1986 560 SEC
1991 500SL
1982 Holden Statesman DeVille
Raymond
Full Member
Platinum
USA, FL, Jacksonville
Reply #3 on:
March 18, 2012, 22:32:18 »
Franjo,
What color are the spark plug ends and do they appear to twist onto the cable?
Vendor
Platinum
United Kingdom, England, Richmond
Reply #4 on:
March 19, 2012, 07:55:13 »
The PN for the set is 1301501318 and was available quite recently.
Failing that you could try magnecor:
http://www.magnecor.co.uk/
Stick
www.colinferns.com
franjo_66
Full Member
Silver
Reply #5 on:
March 19, 2012, 10:17:50 »
Ray, my car is in the workshop waiting to get a rebuilt hydraulic coupling for the auto.
From memory I think the ends were black. When I get her back I can check the ends, etc and let you know.
Reds
Franjo
Franjo
1983 BMW 735i
1986 560 SEC
1991 500SL
spark plug leads
