Author Topic: is it worth to repair A/C  (Read 8227 times)
ericlee
« on: March 09, 2012, 03:10:50 »
I am thinking have my A/C repaired. But a friend of mine told me it is a waste of money to do that since A/C on w113 car does not work well anyway.  Can anyone please give me your experiences/advices if it is worth to get it fixed?
Eric
hank sound
Re: is it worth to repair A/C
« Reply #1 on: March 09, 2012, 07:56:09 »
Hi Eric,
Yes, it is worth it to get your A/C fixed.   I won't own a car without air (when the sun comes up - I'm hot).   I bought my Pagoda knowing the A/C needed service.
I totally disagree with your friend on this.    After proper servicing, mine now works like a dream, even on days that are in triple digits !!
Do it - you be chilled..... I mean, thrilled :D
Cheers, Hank
johnnymack
  • USA, NH, Meredith
  • 70 280 SL Auto
« Reply #2 on: March 10, 2012, 15:07:13 »
In this part of the country, I don,t need it. I recently rebuilt my engine, and did not put on the bulky bracket or ugly compressor back in . It looks pretty now!  I did keep parts in case I change my mind !
JohnnyMack
70 280 sl auto
Norm
  • USA, TX, Wimberley
« Reply #3 on: March 10, 2012, 16:53:54 »
I also was advised that A/C didn't work very well in 113s, but this is Texas and it gets HOT.  I added A/C two years ago and, after working through some issues (bad A/C compressor clutch, condensation dripping in the cabin, getting my auxilliary cooling fan installed and wired correctly, learning about and changing to Freeze 12 freon) it works fine and I am very glad I have it.   June through September weather is the worst.  Too much sun and heat during the middle of the day to have the top down if you are going to drive anywhere besides around the neighborhood.
Norm
Norm
1966 230SL 162H Blue-Grey
1994 Acura NSX Formula Red
2024 Acura RDX A-Spec, White Pearl
2016 Mercedes S63 AMG Coupe Obsidian Black
2011 Harley Davidson Super Glide Light / Dark Root Beer
ericlee
« Reply #4 on: March 11, 2012, 22:42:57 »
Hi, Norm,
Where did you have your a/c installed? can you share a ball park number of the cost?
Norm
« Reply #5 on: March 11, 2012, 23:52:53 »
Helmut Holder did the installation.
Unit plus installation was around $3400.  Including adding the aux fan.
PM sent.
Norm
Norm
ericlee
« Reply #6 on: March 12, 2012, 00:32:19 »
Norm,
Thank you very much for the info and you have a very nice car.
hank sound
« Reply #7 on: March 12, 2012, 00:38:06 »
Hi Norm,   May I say - that is a very attractive/professional  (unique) appearing A/C installation.   It reminds me of the way the cabin A/C looked in the older 280SE (and more) models.   But,  if one has the proper MB dealer "aftermarket/dealer installed A/C", it can be tuned to function beautifully !.
As for the current check of my "factory/dealer" stock A/C (FridgeKing) system,  I had no leaks or contamination from any other elements being introduced into the system.
Drive your car, run the A/C - enjoy whatever nature has to offer......... :D :D
Cheers Hank
« Last Edit: March 12, 2012, 01:20:56 by hank sound »
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #8 on: March 18, 2012, 22:17:41 »
Eric,
If the repair shop determines that the compressor is bad, go with a Sanden 508 as a replacement.  They are less expensive than other options and are very efficient.  I have one in my car and it works quite well in the Florida summers.  When the Sanden kicks in, you won't even notice.  There is a "York to Sanden" adapter that bolts onto the existing mounting bracket.  Spacers and longer bolts allow you to align the belts properly.  It isn't "Concours correct", but it is "driving practical".
68_white
  • USA, TX, Houston
« Reply #9 on: March 18, 2012, 23:44:59 »
I installed one in my white. I use it in the summer even with the top down.
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
chumps
  • USA, CA, Santa Rosa Valley
« Reply #10 on: March 19, 2012, 16:55:43 »
Where is the best place to buy the York to Sanden adaptor? Thanks, Chumps
« Reply #11 on: March 19, 2012, 17:38:26 »
Conversion brackets are available from many suppliers (just search on Google for "York to Sanden bracket"). Fore example: http://www.nostalgicairparts.com/air-conditioning/york-compressor-adapter-plate-universal-mount-177.php
There are many kinds available, including one with a structure for adjusting the belt tension: http://www.ebay.com/itm/YORK-SANDEN-SELTEC-ADJUST-COMPRESSOR-MOUNT-KIT-/310322867846#vi-content
This one would of course require more room. Check first to see if you already have an adjustable idler pulley, which can be used to adjust the belt tension.
chumps
« Reply #12 on: March 20, 2012, 16:39:10 »
Thanks for your information. Chumps
