Author Topic: should any of the dash lights work when the doors  (Read 4452 times)
erickmarciano
  • Canada, Quebec, montreal
« on: June 07, 2004, 18:49:36 »
should any of the dash lights work when the doors are opened?<one of the 3 lights on the center cluster?
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
tuultyme
Re: should any of the dash lights work when the doors
« Reply #1 on: June 07, 2004, 19:53:10 »
The center red light will come on when the doors are opened.  This light also functions as the indicator light when there is a malfunction in the brake system.
knirk
« Reply #2 on: June 08, 2004, 00:24:08 »
From the 280 sl Owner’s Manual:
"Brake control light (in instrument cluster, underneath the generator indicator light). The control light will show red if the brake fluid in the reservoir is at the minimum mark (see a MB dealer immediately).
You may check the functioning to the control light by opening one of the doors; the light must show red."
Per G. Birkeland
69 280 sl aut 834
Norway
TA250SL
« Reply #3 on: June 12, 2004, 00:55:56 »
I get a yellow light in my instrument cluster when I open the door of my early 67 Euro 250SL.  Sounds different from everyone else.
« Reply #4 on: June 12, 2004, 02:43:04 »
Tom,
Does your 250 have a 'brake fluid low' indicator switch on top of the brake fluid resevoir?
TA250SL
« Reply #5 on: June 13, 2004, 00:43:40 »
Naj, my car doesn't have a low brake fluid indicator.  It has all the early SL details vs. the later modifications, (#002650).
« Reply #6 on: June 13, 2004, 02:26:46 »
Hi, Tom,
This yellow light was in the cluster in the 230sls as well but not used. It was used for a different purpose in some sedans - there was a thread as I recall.
Some PO may have wired yours to indicate 'open door'.
On my 230, I used it to warn of low oil pressure. I was able to change it to red with a plastic 'window' from another spare cluster.
« Last Edit: June 13, 2004, 02:28:46 by naj »
TA250SL
« Reply #7 on: June 13, 2004, 21:20:56 »
Naj, that is interesting.  In my original 250SL owner's manual, the instrument cluster description does not show the center (yellow) indicator to have a function.  I think I'll keep it wired the way it is for the obvious benefit, and besides, I don't feel like tearing apart the dash again!
