I think I have a full set of Inner door trim with this alignment holes. I also have a latch that fits one of these alignment holes (only have 1 of them). I polished some of the pieces with a very light compound but made sure not to cut any. Most of the pieces are good to very good driver quality.
As for mechanical pieces, I have a set of motor mounts. One of which has an oil pump?/filter still attached. I also have a throttle body and a manual shifter (not sure if it's a 4 or 5 speed). As for the radiator tank, any clue if that's for the 113 models? From the diagrams I've seen they are supposed to look different.
Chances are, I'm going to list the radio delete plate, the air vents, and the inner door chrome sets first. These will fit all 113 models right?
