Author Topic: Rear wheels - negative camber - correct? How to check/adjust  (Read 2965 times)
Paul99
  • United Kingdom, England, Hampshire UK
  • 230 SL White. 1966.
I notice that my real wheels seem to have a slight  negative camber, that is the bottom of each wheel is closer to the center of the car than the top.  Similar to the old triumph heralds (if anyone remembers those!)
Its only slight, but don't think its correct.  How do you adjust this?  Is it correct?    Should there be negative camber on the rear wheels?
Sorry if this has been discussed before - but i cant find it anywhere.
Re: Rear wheels - negative camber - correct? How to check/adjust
« Reply #1 on: March 13, 2012, 20:14:33 »
You are describing positive camber which is correct.
See here:
http://www.sl113.org/forums/index.php?topic=16081.0
