That's why I try not to quote on stuff like this because every engine is so different. There's a basic price for most things and I find that over the long run it's X amount but until you get everything apart, you never really know.
Some engines need valve seats or align bores which isn't usual but I've had to do these things. The right amount is how much it takes to rebuild
your engine. For someone else, it could be less, or a lot more to get to the same place. How your engine was cared for over it's service life has a lot to do with this as well as prior work and how well it was done. Frankly, it's a crap shoot - you might be lucky
and maybe not.
Our friends at Metric Motors quote an average wholesale/retail price. If you engine is toast, as in no useable cores, it
will be more.
I recently installed a rebuilt 190SL engine only to find it was making all kinds of horrid noises.
After inspecting things a bit I found the cam was one tooth advanced and the valves were hitting the pistons. We fixed that and started the engine again and it was still making noise - a deep, ratting, knocking, sort of sound.
We pulled the engine and found that the '' builder ''
had all of the main bearings in upside down! This cut off oil flow to the two outer main bearings as well as number 1 and number 4 rod bearing. The chain rails were all original, the crank gear was almost worn right off, there was a broken cam bearing and the oil pump had dino tracks on it. The valve guides weren't installed properly and the seats were way out of square with the guides. In short, it was a mess. The only good thing about all of this was that it had never been driven - it would have seized up completely. :'(
The pistons were fine but I had to get all new bearings, gears and an oil pump. After I put it all back together and the engine was running again, I took it out for a drive. It went about 1/2 mile and suddenly a huge cloud of steam came out of the engine bay.
The temp gauge was climbing quickly so I shut it off and walked home.
We pulled it back to the shop and found that a freeze plug had popped out of the block. The builder used silicone to seal all of the plugs in.
This stuff is just slippery enough that it's the worst thing you can use. So, we pulled the engine out again and I took it the hour and a half drive back to my machinist. These are the disc shaped freeze plugs and if they aren't knocked in just right they'll come out again. I wasn't even going to try this job I'd never done before.
The engine is back in the car running - three installs and two removals later. Now I ask you, how in the hell could anyone foresee all those problems and and come out on top with an early quote on the job?
