Author Topic: 280 sl. engine gets a lot of gasoline  (Read 4869 times)
ola
« on: March 19, 2012, 19:10:41 »
what makes Mon gasoline-air mixture?
ola
Re: 280 sl. engine gets a lot of gasoline
« Reply #1 on: March 22, 2012, 08:19:51 »
other similar objects are cold start valve to 280 sl?
« Reply #2 on: March 22, 2012, 20:52:38 »
Hello Ola - please use the technical manual, the search function and items like the linkage tour to cover the basics; that will probably get you 90% of the way there. Then if you run into difficulties on specific items, we can help better. Right now your questions seem very broad and it's very difficult to advise without some more guidance.
twistedtree
  • USA, VT
« Reply #3 on: March 22, 2012, 21:55:43 »
And I'm having a very hard time understanding what you are asking.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
ola
« Reply #4 on: March 22, 2012, 22:10:45 »
rich mixture ...
280 sl. how you adjust air / fuel mixture?
twistedtree
  • USA, VT
« Reply #5 on: March 22, 2012, 23:04:33 »
Take a look here http://www.sl113.org/wiki/Main/HomePage
There is one section that is critically important to read and follow is called the Linkage Tour. http://www.sl113.org/wiki/Restricted/Linkage-tour
You will need to sign up as a full member to access it, but believe me, it's worth every penny plus more.  You will get back your contribution X10 from this site.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
