Author Topic: 280sl Parking Brakes  (Read 2983 times)
69280sl
  • USA, IL, Elk Grove
« on: March 21, 2012, 19:17:31 »
Has anyone changed the shoes for...? I'm told it's a labor intensive process and hardly worth it.
Gus
Gus
Re: 280sl Parking Brakes
« Reply #1 on: March 22, 2012, 22:29:49 »
You can find a lot of information on this process in the "rear axle" and "rear wheel bearing" information on this site. Yes they are a bit complex but not that bad a job if you have the information in front of you.  Normally these little shoes do not wear out, since they are iused when the car is not moving as a parking brake.
Accidentally running with the emergency brake on or damage from corrosion can result in the need to  replace these small shoes .
The early workshop BBB has a fairly good description of the procedure (Sec. 42-28) also.
69280sl
« Reply #2 on: March 23, 2012, 01:02:28 »
Thanks Joe
Gus
