And those difference is the oval and squared combustion chambers right?
And what do you use instead of anti freeze?
BTW, i found something on the Elring site, see attachement.
Article 209.423 says the following:
Transmission Type: Automatic Transmission, To Eng. No.: 2-008784, Supplementary Article/Supplementary Info: Without valve cover gasket, Without valve stem seals, Bore Ø: 87,5 mm
This should mean that there is a gasket for the earlier engine with a boresize of 87.5mm.
Now, what i do better. Buy this one or buy the original gasket which is smaller in diameter?
