Please check out joining the
Emergency Contact List
for help during your travels!
Fan Shroud bolts
Topic: Fan Shroud bolts (Read 2402 times)
rb6667
Fan Shroud bolts
April 01, 2012, 20:33:49 »
Hello All, I am hopeful someone can tell me the metric size hex bolts that are required to mount the fan shroud to the radiator. The captive cage nuts are there. Just need to know what size metric bolts to get.
Thanks in advance.
RB6667
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Fan Shroud bolts
April 01, 2012, 22:13:47 »
I'm thinking maybe 4mm which would give you an 8 mm head.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
rb6667
Reply #2 on:
April 01, 2012, 22:18:49 »
Thanks Doctor!
Fan Shroud bolts
