Author Topic: Clutch Fluid  (Read 8068 times)
peller
Clutch Fluid
« on: April 03, 2012, 21:45:54 »
I recently aquired a '68 and have noticed that the small clutch fluid reservor behind the master cylinder was dry. Before adding anything to it, does anyone have recommendations on things to check for leaks? Looks like it has been dry for quite a while. The clutch seems to be working fine interestingly enough. What type of fluid do you recommend?
Learning as I go... Thanks for helping a newbie out.
twistedtree
  • USA, MA, Gloucester
Re: Clutch Fluid
« Reply #1 on: April 03, 2012, 22:14:43 »
Well, the obvious places would be the clutch master or the clutch slave cylinders.  On one of my cars when I went to remove the reservoir then metal line between it and the master broke right off from corrosion.
Check carefully around the master and slave to see if you can spot any leaks.  If you pull back the rubber boot on the end, you might find the problem.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
JimVillers
  • USA, VA, Virginia Beach
Re: Clutch Fluid
« Reply #2 on: April 04, 2012, 13:06:13 »
Peller ... Brake fluid is used for the clutch.  Unless you want to replace the slave cylinder, just fill the reservoir and watch for leaks over time.
Jim Villers
peller
Re: Clutch Fluid
« Reply #3 on: April 04, 2012, 19:28:00 »
Does the brake fluid type matter? Dot 3,4,5?
Thanks!
peller
Re: Clutch Fluid
« Reply #4 on: April 11, 2012, 17:32:14 »
Found a leak on the hose leading from the clutch reservoir to the metal tube in the firewall.  Removed the reservoir, cleaned up the corrosion on the metal tube and I'm ready to reinstall. Trouble is that hose running between the reservoir and the metal tube needs replacing...
Is this a special hose, or can I just cut a similar diameter hose to fit?
Thanks!
bdo1
  • USA, IA, Des Moines, IA
Re: Clutch Fluid
« Reply #5 on: April 15, 2012, 19:49:49 »
DOT 5 works great in my 69.
bdo1
peller
Re: Clutch Fluid
« Reply #6 on: April 16, 2012, 16:04:15 »
Hose replacement complete. It was a little tricky because the hose needs to be 3/8th on one end and 1/4 on the fitting on the firewall. Tough to find. After combing through the back room at the local auto parts store, decided to sleeve in short piece of fuel line  inside of the 3/8 hose. Fit nicely, and with a small hose clamp, it works great.
I loaded it up with some DOT 4 i had and everything looking great.
Re: Clutch Fluid
« Reply #7 on: April 16, 2012, 23:54:43 »
That hose is an available part. There are at least two or three different versions so you have to be exact when ordering.
twistedtree
Re: Clutch Fluid
« Reply #8 on: April 17, 2012, 01:27:17 »
Keep in mind that not all DOT variants of brake fluid are compatible with each other.  In particular, it's my understanding that DOT 5 can't be mixed in any way with DOT 1-4 since 5 is Silicon based and the others are Glycol based.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
Re: Clutch Fluid
« Reply #9 on: April 17, 2012, 07:44:09 »
Also keep in mind that hose is NOT just hose. There are different materials used in hoses according to the fluid that they are required to transport. Using the wrong type of material can very quickly lead to the hose failing.
peller
Re: Clutch Fluid
« Reply #10 on: April 17, 2012, 14:04:28 »
Point taken, but so far this solution has worked. I'll report if I see any premature failure in this case.
Re: Clutch Fluid
« Reply #11 on: April 17, 2012, 22:57:06 »
Also, this is a high pressure hydraulic line. Chances of a fuel line lasting at all are slim.
