Author Topic: Relay replacement  (Read 7971 times)
KUMARB
Relay replacement
« on: April 05, 2012, 01:44:21 »
Could anyone please care to comment on pros and cons of replacing the original relays in the engine compartment to newer type of relays?  There appears to be 3 Bosch relays in metal cans, two of them with four round pins and the third one with five round pins. These have metal contactors inside which are prone to pitting. Newer relays are probably better made, less costly, and have plastic covers and flat pins. Any advuce? Other than the need for connection modifications and the loss of originalty, what else could be the down side for this change?
Thanks.
Re: Relay replacement
« Reply #1 on: April 06, 2012, 19:51:18 »
The Bosch relays with round pins are still availiabe and around $100 +/-. I doubt they are better made but require no modifications. Generally, the old ones last a very long time. If the coil is still good, the points can be cleaned with microfine paper, contact cleaner and all is good. That is unless the points are badly burned or pitted.
You can refinish the exterior of the metal can and replace the decals that they came with and it will look new again. See the post below. I have the parts to do this.
 http://www.sl113.org/forums/index.php?topic=13761.0
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #2 on: April 08, 2012, 23:22:38 »
In terms of function, there is no downside.  I recall reading a post from someone who put an inexpensive Radio Shack relay inside the original metal cans.  I haven't needed to search for that for a long time because, as Wheeler said, cleaning the contacts solved the intermittent problem that was developing.
KUMARB
« Reply #3 on: April 16, 2012, 14:27:36 »
Thanks for sharing your thoughts.
I did not think these relays were meant to be reopened and reconditioned.  Insulation on the coils deteriorates.  I have ordered new rellays. If nayone needs old ones, let me know. Thanks again.
PeterW113
« Reply #4 on: January 11, 2013, 00:08:08 »
Hi, sorry for tagging onto this post, but my windscreen washer water jets are not working and the problem appears to be one of the relays.  The washer jet motor spins when when tested on a bench, but when in situ the relay just clicks. Does anyone know if the relays are reparable ?
Thanks in anticipation.
1968 MB 280SL, RHD Auto
1968 Lotus Elan +2
1965 Fiat 500
2004 BMW 1200 GS
Flyair
« Reply #5 on: January 11, 2013, 12:44:33 »
Peter,
you may try to call:
Auto-Electrical 01626364081 or
Si-Leck Autoelectrical 07831 262878, or
AutoMobile 07836712057
They were recommended as specialist for Mercedes cars.
If you decide to replace, I think that these guys offer it at a still very high, but lower price compared to others :)
http://www.starpartz.co.uk/products/w108-w109-111-w113-sl-wiper-motor-relay.html
good luck
« Last Edit: January 11, 2013, 12:54:03 by Flyair »
Stan
2011 SL550 AMG
2011 GL
2015 GLA
PeterW113
« Reply #6 on: January 12, 2013, 09:22:18 »
Stan,
That's very helpful, thank you.
1968 Lotus Elan +2
1965 Fiat 500
2004 BMW 1200 GS
« Reply #7 on: January 12, 2013, 11:51:41 »
Hello, Peter,
Thre may be a fault with your column switch or wiring.
The windscreen washer pump runs off the switch. No relays are involved.
Naj
PeterW113
« Reply #8 on: January 12, 2013, 12:46:12 »
Hi Naj,
Just moments before I ordered the relay, looks like I may now have a spare?
Many thanks all the same and I will also investigate the switch.
1968 Lotus Elan +2
1965 Fiat 500
2004 BMW 1200 GS
« Reply #9 on: January 12, 2013, 18:28:28 »
Peter,
you can test the switch/cables as described here - no need to remove the complete switch - just test resistance between the connector pins:
http://www.sl113.org/wiki/Electrical/SteeringColumnSwitch
PeterW113
« Reply #10 on: January 13, 2013, 17:56:21 »
Alfred,
Many thanks for pointing me in this direction.
Regards
1968 Lotus Elan +2
1965 Fiat 500
2004 BMW 1200 GS
