Author Topic: Turbo Pagoda - really!  (Read 3527 times)
« on: June 10, 2004, 23:22:01 »
Arnold Popky has listed his car in the registry with a 5spd and turbo engine:
http://www.sl113.org/data/carreg/show_table.asp
Albert-230SL
Re: Turbo Pagoda - really!
« Reply #1 on: June 11, 2004, 03:35:04 »
[:0]... So the rear badge of this Pagoda should be "240 SL TD" or "240 SL Turbo Diesel"  ;)
Albert de la Torre Chavalera
Barcelona (Catalunya/Spain)
« Reply #2 on: June 11, 2004, 08:42:57 »
Hasn't Walter Klatt been working on one of these?
« Reply #3 on: June 11, 2004, 08:45:35 »
Michael - Walter reported working on a diesel SL but to my knowledge this project has not yet been completed. Also I don't think this was a turbodiesel. I owned a white 1982 W123 300D turbodiesel for a while, living in Florida. It was one of the most pleasant cars I ever owned.
« Last Edit: June 11, 2004, 08:47:18 by cees klumper »
« Reply #4 on: June 12, 2004, 04:35:15 »
I had thought about adding a turbocharger to my car and went as far as to buy a spare engine so I could sacrifice that to the cause as opposed to the original. After some thought I realized that besides the fact that the engine is already 9.5 to 1 compression and the exhuust plumbing whould be a chore there is still the issue of having to change over the fuel system in order to allow for boost enrichment. I guess you could pipe a small tube over to the atmospheric diaphragm on the injection pump but that still would not be precise enough to keep from toasting a piston or two.
 The end result is I like it just fine the way it is.
