Author Topic: tech manual distributor rebuild  (Read 2806 times)
rmmchl
  • USA, WV, Charleston
« on: April 25, 2012, 22:56:54 »
I was reading our new tech notes for members. I was wondering what the symptoms would be if a distributor is worn  or going bad ?
michael romeo
1967  250sl
signal red
SQUIRT
Re: tech manual distributor rebuild
« Reply #1 on: May 09, 2012, 22:46:38 »
For me, the first symptom would be the timing wouldn't be constant (dist. not locked in) 2nd would be a "clicking" sound on acceleration (perhaps dwell) last resort could be a worn worm gear (pull dist. drive & inspect). Truth is: you won't know until you pull the entire dist. out & inspect, re-install with correct timing.
