Author Topic: Whining sound from speedometer or tach  (Read 4462 times)
tradjim
« on: May 09, 2012, 00:46:17 »
Not sure exactly which one but the sound increases and decreases with speed ....any ideas ?
PeterW113
  • United Kingdom, Blackheath, London
Re: Whining sound from speedometer or tach
« Reply #1 on: May 09, 2012, 06:44:25 »
It might have to be a process of elimination.
If you think it’s the tachometer and you have an auto, the cable can be separated from the transmission and the centre cable/wire can be removed for greasing. It’s fiddly but no where near as much work should you have a go from the tacho end.
There are several threads on this subject.
1968 MB 280SL, RHD Auto
1968 Lotus Elan +2
1962 Ford Thunderbird
2007 BMW 1200 GS
« Reply #2 on: May 09, 2012, 07:43:31 »
It's the speedo
Mine whines whenever I go too fast or try to overtake. Only happens when the wife is in the car though
(ba da boom, tish)
tradjim
« Reply #3 on: May 09, 2012, 12:45:54 »
I have a 4 speed manual
guscarfi
« Reply #4 on: May 24, 2012, 12:30:06 »
I have thecsame issue on my 280 the whinng comes and goes for no apparent reason my specialist mechanic swears its theccable on the speedo that needs replacing
philmas
« Reply #5 on: May 24, 2012, 14:11:49 »
I think this is a common issue.In my case , greasing nor even changing the cable didn't make any difference.
The problem was inside the speedo (or tacho?) itself.
It had to be removed (not an easy job!) and greased and has been running quiet since then.
« Last Edit: May 24, 2012, 14:20:33 by philmas »
Philippe from Paris
Euro '71 280SL manual 4sp
Atazman
  • USA, Ca, Pleasanton
« Reply #6 on: May 24, 2012, 15:14:25 »
My experience is the same as Philmas.............greased the internals of the tach and it has been quiet ever since.
Don
67 250 Sl
(#3168) from Italy
5-speed/Posi/AC/Kinder
