I have never had enough success with the "bump the starter" approach, to recommend it to anyone. People say you may need to do it several times to get it right.... yea, maybe several hundred times, if you're trying to really get TopDeadCenter!
Best approach is like Cees initially said - put a 27mm socket on the crank nut with a shorty extension, and use a 1/2" rachet to turn the crank. Someone else watching the harmonic balancer for the TDC mark is most helpful. Otherwise, you will be getting up and down a lot. If the thing is too hard to turn, remove all 6 spark plugs to eliminate cylinder chamber compression. This makes it a LOT easier.
One thing is for sure, IMHO - NOTHING is easy to do on this car! ...so don't bother looking for the easy method of accomplishing something (like bumping the starter to find TDC). Just take the extra time, energy, and resource to do it right. ...just my humble opinion.
1971 280SL US Automatic
