Author Topic: Steering Shaft Nut Size  (Read 2425 times)
George Des
« on: May 16, 2012, 20:45:29 »
I've dinged up the steering shaft on my 230SL while re-installing the column. I need to dress up the shaft and replace the nut. Anyone know what size nut the shaft takes? Looks like it could be either a 16MM or 15MM but the nut has also become damaged in the process and I'm not sure at this point. Got a feeling this is another odd ball sized nut that MB uses.
George
Re: Steering Shaft Nut Size
« Reply #1 on: May 16, 2012, 22:25:01 »
George,
if it is #88 as shown in the drawing that you have in mind  then it is p/n 000936 014008 = M 14 x 1.5
George Des
« Reply #2 on: May 16, 2012, 23:38:48 »
Thanks, Alfred--that's the one!
George
