Author Topic: window felts  (Read 4514 times)
jmbour
  • France, Ile-de-France, Paris
window felts
« on: June 14, 2004, 19:46:23 »
I would like to change the window felts on my 1971  280SL
do I need to take off the door panel, or is it possible to change them from the outside ?
Thanks for you help
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
Re: window felts
« Reply #1 on: June 14, 2004, 23:07:17 »
They're held in place by small clips and you will need to remove the door pannel get at everything. The replacements are longer than you need so you will need to cut them shorter. I use a pair of shears or a bolt cutter to give a nice straight edged finish. The ends are actually notched a small amount to help clear the sliding jaws on the door glass. You should try to carefully remove the old ones and use them as templates.
I always lubricate all the moving parts inside the door when ever the door pannel is off. Something that really isn't done often enough to prevent wear on most cars.
Daniel G Caron
jmbour
Re: window felts
« Reply #2 on: June 15, 2004, 06:10:39 »
Do I need also to take off the chrome trim on the top of the door ?
J.M. Bour
Daniel G Caron
JMB
1971 280SL US
1973 280CE
1987 300 E
2005 C230
ted280sl
  • USA, NY, New Rochelle
Re: window felts
« Reply #3 on: June 15, 2004, 16:52:27 »
My recollection is that the clips that hold the chrome on the outside also hold the outside felt. I removed my chrome when I replaced the felt. While you have the door panel cover off it is a great time to tighten all of the bolts and adjust the plastic pads in the jaws.
Ted
