Author Topic: What's the function of that switch?  (Read 5161 times)
Eminent
« on: May 19, 2012, 21:21:06 »
Hello all.
Whats the function of the switch as shown in the attachement?
Now i have put the linkage back together but the switch is not operated at any point.
Is this correct?
I didn't change the lenght of the rods, just put everything back together as it was (i believe).
Thanks.
Eminent
Re: What's the function of that switch?
« Reply #1 on: May 20, 2012, 18:43:36 »
Could it be a fuel cut off switch, in case something happen with the linkage/control shaft?
« Reply #2 on: May 21, 2012, 19:47:26 »
Quote
Looks like aftermarket stuff to me. ???
Where do the wires go?
If I were you I'd leave it out of the car (as I did with the tons of remaining relais for extra horns and other unnecessary and uggly stuff).
Car will certainly run fine without that box.
IMHO...
Eminent
« Reply #3 on: May 21, 2012, 20:19:02 »
Wel it's not aftermarket.
After a few days deep searching this forum i found This topic.
Take a look there.
At my car this switch is not working no matter what position the regulating shaft is.
I think it is because my car is running on LPG (or GPL) and therefore disabled.
Thanks for your thoughts anyway.
« Reply #4 on: May 24, 2012, 19:51:13 »
That switch tells some component that the throttle linkage is at idle or not. The spring loaded screw adjusts for that purpose. It is a factory device. My understanding is that depending on emissions and equipment, that switch can do a number of things.
On my '68 W111 w/ automatic, it tells the fuel shut off system that the linkage is at idle. Your Euro car may be different.
Eminent
« Reply #5 on: May 24, 2012, 20:32:50 »
My '68 W108 is from California so i think it's pretty the same.
Buit as i said, this car drives a cheaper fuel, called LPG.
When the car switch over to LPG there is a sort of vacuum-switch (which is mounted at the front of the FIP) wich cut off the fuel at the same way.
Thats why i think the switch is disabled.
« Last Edit: May 25, 2012, 08:21:40 by Eminent »
