Author Topic: Extreme Shifter Bushing Wear + Bushing Install Tip  (Read 2761 times)
ctaylor738
  • USA, VA, Falls Church
« on: May 23, 2012, 19:16:42 »
Well, it certainly explains the play - I am amazed that it could still be shifted.
« Last Edit: May 24, 2012, 15:32:49 by ctaylor738 »
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
ctaylor738
Re: Extreme Shifter Bushing Wear + Bushing Install Tip
« Reply #1 on: May 24, 2012, 15:42:04 »
The replacement bushings are not all that easy to install.  They slip into the hole in the selector, and then you need to force the linkage over them because the fit is very tight.  I ended up positioning the linkage above the selector and smacking it with a hammer to drive it down and get the holes to line up.
Chuck Taylor
1963 230SL #00133
Falls Church VA
