Author Topic: Double acting solenoid  (Read 4374 times)
Larry & Norma
« on: May 26, 2012, 14:11:32 »
The wiring diagram (US Version) in the Technical Manual is incorrect in my opinion.
Item 51 is misnamed as 'idle increase solenoid' and should be 'double acting solenoid'
Anyone agree?
Has anyone made a note of the wire colours on the autogearbox terminal strip?
ie Idle switch, kickdown switch and double acting solenoid colours.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
glenn
Re: Double acting solenoid
« Reply #1 on: May 27, 2012, 16:02:21 »
Agreed...  We all need the correct wiring diagram and the accompanying correct explanation of how it's s'posta work. ..
« Reply #2 on: May 27, 2012, 19:52:30 »
I am not sure whether this is of any help but there is a cautionary note with an explanation already in the technical manual (but I don't know how to interpret this):
Note: The description "Idle Increase Solenoid" for item 51 on "280SL (US Version) Wiring Diagram" is incorrect. The idle increase soleniod is uni-directional (extended when energized, spring return), whereas the solenoid on the schematic is bi-directional. What is shown appears to be the transmission solenoid which is three position with two coils, extended, mid positon, and retracted. The wiring indicates extended positon when the "venturi control switch" is closed, and retracted position when the "kick down switch" is closed, which is the function of the transmission solenoid. The "Idle Solenoid" does not appear on this schematic, nor do the forward and reverse auto-transmission pressure switches.
Also the wiring colors from the double-lift-solenoid [or double-acting-solenoid] are brown-yellow-and black, where the two brown wires end in a single larger terminal connector than the other two.
How they are connected to the terminal strip is mentioned on page 27-26/7 in the BBB - see attached photo.
Larry & Norma
« Reply #3 on: May 28, 2012, 07:50:56 »
Thanks Alfred that is a great help
Just discovered that the wire colours etc are in the technical manual under the automatic
gearbox section :-[ :-[
« Last Edit: May 29, 2012, 07:51:41 by Gnuface »
2023 Ioniq6
2005 C230
