Author Topic: Could it be "vapor locke"  (Read 4798 times)
ptruty
« on: May 28, 2012, 01:27:34 »
After two years of sitting idle got a major tune up for my 1964 230 SL.  Runs like a swiss watch.  After a long run 30+ minutes or stopping to refuel, I cannot get it restarted until it sits for 30-40 minutes.  Has anyone had this  problem?  It is very frustrating and leads to distrust on taking it for much needed drives.  It has always had this problem.  Help?
glenn
Re: Could it be "vapor locke"
« Reply #1 on: May 28, 2012, 15:07:52 »
Sounds like the 'crud in the tank'.   Crud blocks the refilling of the quart sized plastic vessel in the tank.  Do a 'search' for a mountain of info. ..
« Reply #2 on: June 03, 2012, 14:41:02 »
If you have fuel, and spark the engine will start.  Check for spark first. New ignition points sometimes "seat" and close up. Re-adjusting them solves the problem. If you have spark, try a shot of starting fluid to diagnose the problem. If the car start right up your problem is fuel related.
Keep us up to date.
enochbell
« Reply #3 on: June 03, 2012, 15:44:55 »
...and if you follow Joe's diagnosis and find that the shot of fuel works, then you can remedy by adding a manual CSV actuator.  I had the same problem in my '64, it would not start "hot" (after running for 10+ minutes).  I just installed a discrete (under dash) pushbutton wired to the CSV to allow momentary actuation of the valve.  Problem solved...inelegantly...but solved.  I believe this problem is common in early 230sl models, and that later versions of the starting systems corrected for it.
g
ctaylor738
  • USA, VA, Falls Church
« Reply #4 on: June 14, 2012, 18:00:52 »
You may have a slow-turning starter contributing to the problem.  They draw a lot of current, leaving little for the ignition and the fuel pump, and the mechanical pump is turned too slowly to deliver enough fuel to get past the vapor lock.
I worked on a 250SL with this problem, and a rebuilt starter cut the hot start time from 10-15 seconds to 2-3.
The solenoids on these starters have a terminal to output battery voltage while cranking, so you can run a wire from that terminal to the + side of the coil to provide a hotter spark when cranking.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
« Reply #5 on: June 15, 2012, 05:04:11 »
Also the later W113 starters had 40% more horse power than the early starters. Use the later starter if you have a choice.
