Author Topic: Stange wire along coil wire  (Read 3180 times)
Michael C
« on: June 26, 2012, 21:25:21 »
Hey all,
I purchased a new coil wire from the dealer today.  The coil wire a a bundle tube on it with a second small thin wire with two eyelets attached to it.  Is this a ground wire or something?  If so, where does it go?
Never had a ground wire (or secondary wire) before.  Any insight would be great.
Michael
Re: Stange wire along coil wire
« Reply #1 on: June 27, 2012, 09:28:47 »
Hi, Michael,
I suspect you have a 70/71 car with transistorised ignition?
This wire bundle is for the earlier cast iron distributors. The smaller wire goes from coil primary to insulated terminal on the distributor for the points.
Naj
